We are using RH6 to generate Webhelp with option: No Java
Applet, DHTML > Pure HTML.
Installed the resulting help files on a server at a customer
site. The help works fine when called up from one networked client
PC, but on another an error occurs and the table of contents fails
to populate. The error is reported as "Automation server can't
create object", and the URL is reported as the file
whskin_pdhtml.htm
Both clients are running Windows 2000 with Service Pack 4.
Both are running the same version of IE 6, specifically
6.0.2800.1106C0
The "security" and "advanced" options in IE 6 are configured
exactly the same with two exceptions:
1. The one where it works is set to "empty temporary internet
files when browser is closed", the failing client is not. I would
suspect this is irrelevant.
2. On the client that works, when I view the security
configuration, the first item in the list is "Permissions for
components with manifests", which is set to "High". On the failing
client, this configuration entry does not appear at all. Possibly
this is a clue that the failing client is missing some Microsoft
component/feature that is required in order to be able to display
the text list that is the table of contents?
I understand that W2K and IE 6 are "obsolete", but
nevertheless my hope is to generate help screens that my various
customer sites can run reliably on their current Windows PCs.
Can you offer any helpful insight as to why this failure is
occurring, or how to get past it?
