1 Reply Latest reply on Mar 28, 2008 9:35 AM by (Lin_Xia)
    Is it possible to find an associated text frame from an XML Tag
      Hi.
      Any help appreciated.
      My problem is I have some frames in an ID document I am duplicating with Javascript from an XML file I am processing with instructions for lay out.
      My problem is that the only way I can access the frames is to get them by the order they appear on the page. This is not a good solution as it is possible that at a future date a designer may add frames to the template which would stop the script from working. Is it possible to find the text frame from the XML tag it is associated with? I know this is possible in the actual application but what I would like is to get a reference dynamically in the script.
      TextFrame.itemByID works but is no use because the ID seems to change when new elements are added to the document.
      I feel I must be missing something...
