4 Replies Latest reply on Apr 15, 2008 12:22 PM by (Jonathan_Hodges)
    [AS, CS3] Delete pages by range?
      Hi:
      I can kill pages in my Applescript individually:
      delete page 1 of document 1
      Can I set a page range to kill, such as delete pages 3-8 without having to do them one at a time?
      Thanks.
        • 1. Re: [AS, CS3] Delete pages by range?
          sstanleyau Level 4
          Try:<br /><br /> delete pages 3 thru 8<br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au>
          • 2. Re: [AS, CS3] Delete pages by range?
            Level 1
            Shane:
            Thanks. Thought I had tried that syntax, but I guess I didn't.
            Can I bug you on a follow up?
            The deleting pages part of my script is going fine. Now I also want to be able to delete pages as spreads.
            I have a document set up as reader spreads (cover by itself, then two-page spreads with the back cover by itself at the end). I want the script to kill spreads so I can save out the spreads in individual documents.
            What's happening is page 1 comes across clean (as it's own spread), but everything else winds up as two-page documents no longer side-by-side.
            When I do this manually, I have to unselect page shuffle and spread shuffle, so in the script I put in:
            tell document preferences
            set allow page shuffle to false
            set preserve layout when shuffling to false
            end tell
            but that doesn't seem to do the trick. If you have a three-page document with pages 2-3 as a spread, is there any way to kill page 1 and still leave 2-3 in spread formation?
            Thanks.
            • 3. Re: [AS, CS3] Delete pages by range?
              sstanleyau Level 4
              On 15/4/08 1:24 AM, "Jonathan Hodges" <member@adobeforums.com> wrote:<br /><br />> If you have a three-page document with pages 2-3 as a spread, is there any way<br />> to kill page 1 and still leave 2-3 in spread formation?<br /><br />You also need to set "allow page shuffle" of the second spread to false --<br />it's a property of both document preferences and spreads.<br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au>
              • 4. Re: [AS, CS3] Delete pages by range?
                Level 1
                Shane:
                That worked like a charm.
                Many thanks.
                --jon
