2 Replies Latest reply on Apr 15, 2008 4:46 AM by (mears)
    [AS][CS3] mathtype replace script
      Hi, I edited the mathtype importscript to work better with the selection method.
      In CS2 it was working fine, in CS3 not any more of course after I converted my document to the new version and wanted to replace the tect to inline graphics.
      Problem is off course the find function, it gives an error on «event K2 Find»
      I have read some topics but need some help on what I should alter, of course «event K2 Find» but is this the only line or should it be completely rewritten?
      Here is the script:
      Deleted some intro info or it's too long.
      -- get the source folder for the equations from the user and compile a list of the enclosed files
      set the sourceFolder to choose folder with prompt "Select the directory containing the equations:"
      set the fileList to list folder sourceFolder without invisibles
      -- step through each file in the list, search for a matching name tag in the active document, and
      -- replace with the file and move the baseline of the placed equation
      repeat with i from 1 to the number of items in the fileList
      set currentItem to item i of the fileList
      set currentFilePath to ((sourceFolder as string) & currentItem)
      -- test if the filename is not a folder and then place it
      if (info for (currentFilePath as alias)) is not folder then
      set searchstring to "<<" & currentItem & ">>"
      place_file(searchstring, currentFilePath, get_baseline(currentFilePath as alias))
      end if
      end repeat
      display dialog "Finished placing files from the folder " & (sourceFolder as string) & "."
      * place_file():
      on place_file(fileName, filePath, fileBaseline)
      tell application "Adobe InDesign CS3"
      -- test that a document is open
      if (count documents) > 0 then
      set myDocument to active document
      tell myDocument
      -- search for all references of the filename
      b «event K2 Find» story given «class for »:fileName
      set hitz to the result
      set lapz to the number of items of hitz
      if lapz > 0 then
      -- repeat for each reference to the file
      repeat until lapz = 0
      select item lapz of hitz
      -- get a reference to the selected text
      set myInsertionPoint to item lapz of hitz
      set myRef to myInsertionPoint
      tell item 1 of myRef
      set myInsertion to index of first character
      set myInsertion2 to index of second character
      set myStory to parent of first character
      -- delete the string at the reference point
      set contents to ""
      end tell
      -- place the file at the insertion point
      tell (insertion point myInsertion of myStory)
      place filePath
      end tell
      -- select the inline graphic
      select text from insertion point myInsertion to insertion point myInsertion2 of myStory
      set graphicLocation to object reference of selection
      set myGraphic to item 1 of all graphics of item 1 of graphicLocation
      set mySelection to parent of myGraphic
      -- move the graphic equivalent to the baseline for that inline graphic
      move mySelection by {"0pt", fileBaseline}
      set lapz to (lapz - 1)
      end repeat
      end if
      end tell
      end if
      end tell
      end place_file
      (********** get_baseline():***************)
      on get_baseline(myFile)
      set matchText to "%%Baseline: "
      set theBaseline to ""
      -- read in the EPS file
      open for access myFile
      set fileLines to read myFile as string using delimiter {return}
      close access myFile
      -- find the line with the baseline
      set lapz to the number of items in fileLines
      repeat until (lapz = 0) or theBaseline begins with the matchText
      set theBaseline to item lapz of fileLines
      end repeat
      -- extract the baseline number
      set theBaseline to characters -2 thru -1 of theBaseline as string
      -- return the baseline number
      return theBaseline & "pt" as string
      end get_baseline
        • 1. Re: [AS][CS3] mathtype replace script
          sstanleyau Level 4
          On 15/4/08 7:15 PM, "mears" <member@adobeforums.com> wrote:<br /><br />> tell myDocument <br />> -- search for all references of the filename<br />> «event K2  Find» story given «class for »:fileName<br /><br /><br />You'll need something like:<br /><br />    set find text preferences to nothing<br />    set find what of find text preferences to fileName<br />    tell myDocument<br />        find text<br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au>
          • 2. Re: [AS][CS3] mathtype replace script
            Level 1
            Hi Shane, I have placed it like this and it works now, many thanx
            tell myDocument
            find text
            if lapz > 0 then
