2 Replies Latest reply on Apr 24, 2008 4:53 AM by (poojayadav)
    image palcement JS
    Level 1
      Hi folks
      I have one old script and it was working very fine for InDesign CS2. I am learning JavaScript, and I want to convert it in JavaScript. Can any one help me out.
      tell application "Adobe InDesign CS3"
      tell document 1
      set baselineVar to "Yes"
      set countVar to 0
      set imageCount to 0
      set docPath to file path as alias
      tell application "Finder"
      set imageFolder to folder (choose folder with prompt "Please choose the folder containing the appropriate MathType files")
      end tell
      activate
      set allStories to stories
      repeat with s from 1 to count of items of allStories
      set theStory to item s of allStories
      if class of theStory is story then
      set theLim to count of words of theStory
      try
      repeat with i from 1 to theLim
      if word i of theStory contains "<<" then
      set theText to contents of word i of theStory as Unicode text
      set ImageStyle to "Body"
      if name of applied paragraph style of word i of theStory contains "q" then
      set ImageStyle to "Test"
      end if
      if name of applied paragraph style of word i of theStory contains "ans" then
      end if
      set theOffset to (offset of "<<" in theText)
      set endOffset to (offset of ">>" in theText)
      set imageName to characters (theOffset + 2) through (endOffset - 1) of theText as string
      set imageFolderPath to ((imageFolder as string) & imageName)
      set wholeTag to characters theOffset through (endOffset + 1) of theText as string
      if baselineVar = "Yes" then
      set baseline shift of characters theOffset through (endOffset + 1) of word i of theStory to -10.2
      end if
      delete characters theOffset through (endOffset) of word i of theStory
      tell theStory
      tell word i
      tell character theOffset
      place imageFolderPath as alias
      set countVar to (countVar + 1)
      end tell
      end tell
      end tell
      end if
      end repeat
      end try
      end if
      end repeat
      end tell
      activate
      if countVar = 0 then
      display dialog "No Images were found" buttons "OK" default button 1 with icon 2
      else if countVar = 1 then
      display dialog "1 lonely Images has been placed." buttons "OK" default button 1
      else
      display dialog (countVar as string) & " Images have been placed." buttons "OK" default button 1
      end if
      end tell
      Below is the JavaScript for InDesign CS3. Not completed it in process.
      //Initializing the front document.
      var baselineVar = true;
      var countVar = 0;
      var imageCount = 0;
      var docPath = myDoc.documentPath;
      var myGraphicFolder = Folder.openDialog ("Choose Folder which contains images");
      var allStories = myDoc.stories;
      with (myDoc)
