4 Replies Latest reply on Apr 28, 2008 1:30 PM by [Jongware]
    AS: Getting superscript and subscript font styles
      I'm trying to locate all the subscripts and superscripts in a story and change their applied font. When I run this script it works fine:
      set styleSubList to (object reference of every text style range whose position contains subscript) of story id storyID
      if (count of every item of styleSubList) > 0 then
      repeat with i from 1 to count of every item of styleSubList
      set thisStyle to item i of styleSubList
      -->set ranges
      set startRange to index of thisStyle
      set rangeContents to contents of thisStyle
      set endRange to startRange + ((length of rangeContents))
      -->set font of thisStyle
      try
      set applied font of thisStyle to "Times"
      set font style of thisStyle to "Roman"
      on error errMsg
      return errMsg
      end try
      end repeat
      end if
      if I return the first item of styleSubList I get this as a result:
      text from character 245 to character 245 of story id 173 of document "testfile3.indd" of application "Adobe InDesign CS3"
      from which I can also get all the properties.
      Same script but replace "subscript" with "superscript" and I get an error:
      "Can't get index of \"3\"."
      3 is the character that is superscript in the story. There's only one superscript. If I had a second one to the story it works fine. Any clues? Is there something in my script which I am overlooking or is this a glitch with the Editor or Indesign?
        • 1. Re: AS: Getting superscript and subscript font styles
          Just a though, as I'm more into JavaScript: Shouldn't you have '0' as your first index?
          AppleScript may have a user friendly syntax, but it's still
          i written
          by programmers ...
          • 2. Re: AS: Getting superscript and subscript font styles
            sstanleyau Level 4
            On 26/4/08 4:14 AM, "Steve Suranie" <member@adobeforums.com> wrote:<br /><br />> set styleSubList to (object reference of every text style range whose position<br />> contains subscript) of story id storyID<br /><br />I suspect if you look in your log you'll see that only returns a list if<br />there's more than one instance (or none). Try cutting out the redundant<br />"object reference of".<br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au>
            • 3. Re: AS: Getting superscript and subscript font styles
              I got my Subscript and Superscript fonts from:
              http://www.subscriptfont.com
              • 4. Re: AS: Getting superscript and subscript font styles
                Fascinating. From that website,
                >Issue: < sub > & < sup > tags are not supported by Flash.
                Did you know in ID you can
                * use < sub > and < sup > as font attributes? The sizes and positioning are redefinable in the Preferences. Without any open documents, your changes are set for every new document; with a document open, they are applicable only to that one.
                * use < sub > and < sup > as supplied in OpenType fonts? Tag the text with the OpenType feature [Superior] or [Inferior] and see hand-made sub/superscripts, desgined by the font author (note: support for these varies from one OT font to another).
                * for your totally wack custom super- or subscripts, create a character style? Move the text up and down with baseline shift (only absolute values allowed), scale them with either an absolute size in the Point Size field, or with a relative size in the Horizontal and Vertical Scale fields. In the latter case, you can even make its horizontal scale a teeny bit wider than its vertical one, as it should be.
                ID is just a bit more advanced in this than your average Flash writer.
