13 Replies Latest reply on May 13, 2008 11:46 PM by (Robert_Tkaczyk)
    CS2 JS: Transparency
      Is it possible to find out if a document uses transparencies or not?
      In the user interface I noticed that in the pages pallete, the page icon displays differently if it has a trnsparency (It displays a gray chequered pattern). Is it possible to use this somehow?
      Regards
      Norbert
        • 1. Re: CS2 JS: Transparency
          Is there anybody here who can help?
          • 2. Re: CS2 JS: Transparency
            Level 1
            you need to iterate all objects in indesign and check Opacity and ShadowOpacity
            from VB Object Browser:
            Property Opacity As Double
            Member of InDesign.Rectangle
            The opacity of the object
            Property ShadowOpacity As Double
            The opacity of the shadow
            and in ObjectStyle you have:
            Property EnableTransparency As Boolean
            Member of InDesign.ObjectStyle
            Enable the transparency category of object style
            maybe something more - but I don't know what else
            robin
            www.adobescripts.com
            • 3. Re: CS2 JS: Transparency
              Thanks Robin,
              Isn;t there a quicker way to do this rather than iterate every object?
              How about, in the user interface I noticed that in the pages pallete, the page icon displays differently if it has a trnsparency (It displays a gray chequered pattern). Is it possible to use this somehow?
              Thanks once again,
              Norbert
              • 4. Re: CS2 JS: Transparency
                Level 1
                from script - no
                from plugin - maybe
                but script will do this very quickly ;)
                you work on PC or Mac ?
                robin
                • 5. Re: CS2 JS: Transparency
                  Hi Robin,
                  I work on PC.
                  Are you located in Australia?
                  Regards
                  Norbert
                  • 6. Re: CS2 JS: Transparency
                    Also Robin,
                    The object on a page could be a transparent object from photoshop or illustrator!
                    How do we take this into account?
                    Regards
                    Norbert
                    • 7. Re: CS2 JS: Transparency
                      Level 1
                      if you have Photoshop/Illustrator on same machine - should be no problem ;)
                      I can open file in Photoshop/Illustrator and check for transparencies :)
                      no - I'm not in Australia :( but maybe sometime ;)
                      now I'm in UK :)
                      robin
                      • 8. Re: CS2 JS: Transparency
                        Hi Robin,
                        What I am hoping to achieve is a small part of a huge process and it is not possible to switch between Photoshop/Illustrator/Indesign just to find out if a document has any transparent object in it.
                        By the way, In Indesigns User interface I also noticed A Flattener Preview palette. Window>>>Output>>>Flattener Preview, there is a drop-down list which when All affected objects is selected, it highlights all objects with transparencies including links with transparecies applied in their native application.
                        I looked through the reference guide and could not find anything that would help.
                        Is it possible to somehow use this via a script?
                        Thanks for all the help!
                        Regards
                        Norbert
                        • 9. Re: CS2 JS: Transparency
                          Level 1
                          why it is not possible to switch between PS/ILL/ID ?
                          you don't have it installed ?
                          preview is only preview ... but maybe ;) I have one idea ;) I need to check it ;)
                          robin
                          • 10. Re: CS2 JS: Transparency
                            Hi Robin,
                            Can you give me a hint on your idfea so that I can check this as well?
                            Cheers
                            Norbert
                            • 11. Re: CS2 JS: Transparency
                              Level 1
                              "daredevil" - but works ;)
                              turn on Flatener Preview
                              print screen of each page
                              Color Range in Photoshop
                              if selection is nothing - no transparncy on page ;)
                              robin
                              • 12. Re: CS2 JS: Transparency
                                Hi Robin,
                                I didn't get exactly what you mean by print screen of each page.
                                How am I going to script print screen of each page?
                                Regards
                                Norbert
                                • 13. Re: CS2 JS: Transparency
                                  Level 1
                                  same as PrintScreen key on keyboard ;)
                                  in internet you can find many VB examples of copying screen to clipboard
                                  robin
