3 Replies Latest reply on May 17, 2008 12:45 PM by Dirk Becker
    Two simple SnippetRunner questions which I cannot answer.
      I've started with "JavaScripting" and to be honest I am still confused. I played a little bit with SnippetRunner example.So I have two questions.
      1)Where does "sdkCodeSnippetRunnerObject" name come from?
      In "snippetrunner\examplefiles\scripts\javascript\SnippetRunner.jsx" is this.
      >// get the SDKCodeSnippetRunner object
      var snippetRunner = app.sdkCodeSnippetRunnerObject;
      I understand that in xxxx.fr there is defined "sdkCodeSnippetRunnerObject" object and is added to application object but when I tried to find this string in source codes "sdkCodeSnippetRunnerObject" simply didn't exist....
      2)How can I run some snippetRunner method?
      I wrote this.
      >var snippet = snippetRunner.sdkCodeSnippets.item(53);
      if (snippet.canRun() == true)
      snippet.run();
      but it didn't work. 53 should be PlaceFile snippet.
      pyso
