14 Replies Latest reply on Jun 5, 2008 2:35 PM by (Joel_Berry)
    CreateObject() with ID CS2 broken in Vista (VBA)?
    Level 1
      I posted earlier under a fairly ambiguous subject, so I am re-trying here--forgive the dual post, please...
      but I think I have narrowed it down. It appears to be a problem with InDesign CS2 and Vista. I can't get any application to call CreateObject successfully without an "Out of memory" error on the call: even from the command line using .vbs.
      Does ANYONE have any idea what's going on? Or any ideas? Ole, you out there?
      jdb
        • 1. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
          Level 1
          Hi Joel,
          Several questions:
          Have you added a reference to the InDesign object library in your VBA macro? (I forget to do this every time I update Office--sometimes it carries over; sometimes it doesn't.)
          Can you run .vbs scripts from the InDesign Scripts panel?
          Do you have read/write permissions on all of the folders in the path to the "Resources for Visual Basic.tlb" file (you'll probably have to search for it--lots of places it could be in Vista).
          Ole
          • 2. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
            Level 1
            Thanks, Ole -- yes, I added the reference to the project. I'll check the other two and get back with you. On a side note, I even tried to run it from a C# .net application and got the same out of memory error.
            jdb
            • 3. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
              Level 1
              UPDATE:
              I have modified the permissions on the folders in the path to "Resources for Visual Basic.tlb" (in the C:\ProgramData folder). No joy. Still get an out of memory error.
              I did try running a sample script to create an InDesign Object and then open a file, display the filename and then close the file, then quit InDesign. It worked as a .vbs under the Scripts folder from within InDesign.
              I don't know why I can't script this from a VBA host, though. If at all possible, I would rather not re-do the script as it is designed to run from within Excel, pulling data from numerous sheets, charts, etc.
              UPDATE#2:
              I even tried to create an object from Ruby using WIN32OLE. Here is the message I got:
              C:\Users\Joel\Documents>ruby test.rb
              test.rb:49:in `initialize': failed to create WIN32OLE object from `indesign.application' (WIN32OLERuntimeError)
              HRESULT error code:0x8007000e
              Not enough storage is available to complete this operation. from test.rb:49:in `new'
              from test.rb:49
              Here's the call in Ruby: indesign = WIN32OLE.new("indesign.application")
              Not enough storage? Same as out of memory? Maybe this error code will help? Any more ideas?
              Thanks for your help!
              jdb
              • 4. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                Level 1
                Hi Joel,
                To start with, I think the out of memory error is bogus. It's most likely that something else is wrong, and that InDesign is just tossing that error out as its best guess.
                Next, for a short term solution, you could take the opposite approach: right now, your VBA runs in Excel and contacts InDesign; you could, instead, create a VBScript that you run in InDesign that then creates an Excel object and does its work there.
                We're hearing reports of similar problems from other Vista users--you can see some in this forum. I haven't really been able to track it down, because I'm still mostly running XP, and because the only Vista I have is a VMWare virtual machine (where everything seems to work). I don't have the newest Mac OS release, either--there's just too much work to get done to go through a system update!
                Ole
                • 5. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                  Level 1
                  If I go in and rewrite everything from an InDesign/JScript perspective, I will need to create an object to automate Excel, still, within the application, so I can get info into InDesign.
                  I may opt to code in JavaScript/JScript this time. Do you know the equivalent way in JavaScript/JScript to create an Excel application automation object like CreateObject() in VBA/VBScript?
                  i.e., what in JavaScript is equal to myInDesign = CreateObject("InDesign.Application")?
                  jdb
                  • 6. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                    Level 1
                    Hi Joel,
                    Why not use a VBScript? You've already got the VBA working in Excel, and converting that to a VBScript should be easy. Even if you write the script in ExtendScript/JavaScript (not JScript), you'll have to use a VBScript to talk to Excel--ExtendScript doesn't know anything about Excel.
                    Here's a VBScript that does something in Excel.
                    Set myExcel = CreateObject("Excel.Application")
                    myExcel.Visible = True
                    myExcel.Workbooks.Add
                    myExcel.Cells(1, 1).Value = "Hello World"
                    If you run this from InDesign's Scripts panel, it should create a new workbook in Excel and add text to the first cell. If it doesn't, we might have some other problem.
                    Ole
                    • 7. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                      Level 1
                      Gotcha. I'll try it.
                      Now, for my next trick:
                      Inside my Excel VBA code as it is now, I have created two classes/objects (class modules) that I use to control InDesign (each object stores a bunch of information from various spreadsheets so that I can just create objects as needed and call the methods of the objects to control InDesign. i.e., instead of a top-down script, this is much more modular and keeps the code cleaner).
                      Is there a way to create inline objects in VBScript? That was one of the reasons I was asking about JavaScript/JScript. I need (ideally) to re-create these objects somehow...
                      jdb
                      • 8. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                        Level 1
                        Hi Joel,
                        I *think* there's a way to tell Excel to run its own VBA programs--soemthing like InDesign's DoScript method. It might be that everything you need to do can be done without having to rewrite those functions at all--maybe you can make your InDesign VBScript take care of the only the communication between the applications, while your VBA continues to crunch along in Excel as it always has.
                        In any case, I want to figure out what the original problem is.
                        Ole
                        • 9. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                          Level 1
                          I agree. I hope you do find the problem. If I am having trouble with it, then you can be sure others who have moved to Vista are! ;0)
                          Besides the Ruby script error dump above, check out the following screenshots of my attempts to connect within VB and C# 2005. Maybe they will help guide you in the right direction:
                          http://www.theretailcoach.net/images/vs_InDesign_error.PNG
                          http://www.theretailcoach.net/images/vs_InDesign_error2.PNG
                          http://www.theretailcoach.net/images/vs_InDesign_error3.PNG
                          Hope these help. For some reason, I can't hit the InDesign scripting engine from ANY language or VBA hosting application outside of InDesign itself...
                          This is a brand new, fresh install of Vista. Ironically, when I "upgraded" my system from XP to Vista, it worked, but I was having all kinds of other problems (i.e., legacy code messing up operations in Vista, Vista refusing to update itself on occasion, etc.) so I formatted my machine and did a clean install... I installed Office 2007 before I installed Adobe InDesign CS2, but that shouldn't make a difference, as the type library was available in Office 2007 Excel for me to add to my references for that project, so I don't know...
                          Anyway, good luck. Keep me posted...
                          jdb
                          • 10. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                            Level 1
                            Hi Joel,
                            Does anything happen when you use regtlb.exe to attempt to register the InDesign .tlb file?
                            Ole
                            • 11. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                              Level 1
                              I'll try that. In the meantime, here's something for you. The following script (saved as test.vbs) actually WORKS from the command prompt "cscript test.vbs":
                              ' BEGIN CODE
                              Dim WSHShell
                              Dim myInDesign
                              Dim myDocument
                              Dim myMessage
                              Set WSHShell = CreateObject("WScript.Shell")
                              WSHShell.Run """C:\Program Files\Adobe\Adobe InDesign CS2\InDesign.exe""", 0, False
                              Set myInDesign = CreateObject("InDesign.Application.CS2")
                              myInDesign.Activate
                              Set myDocument = myInDesign.Open("C:\Users\Joel\_Template.indd")
                              set myMessage = new progMessage
                              myMessage.setMessage(myInDesign.ActiveDocument.name)
                              myMessage.Display
                              myInDesign.Quit
                              Set myInDesign = Nothing
                              Class progMessage
                              Private messageText
                              public sub setMessage(s)
                              messageText = s
                              end sub
                              public sub Display
                              msgbox "Message: " & messageText
                              end sub
                              end class
                              ' END CODE
                              So, you CAN create classes within vbs (at least those run from the command prompt and from within InDesign) AND it seems to create the InDesign object just fine. Weird. This code snippet may help your diagnosis...
                              UPDATE:
                              Now, it's not working from the command line. It IS working from the .vbs script in InDesign. Weird. It's always fun trying to find an error when it occurs inconsistently!
                              jdb
                              • 12. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                                Level 1
                                Ole,
                                Where do I get regtlb.exe? I can't find it on my hard drive. Can you send it to me: [joel DOT berry AT hotmail DOT com]? I'll test it if you can get it to me.
                                jdb
                                • 13. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                                  Level 1
                                  Hi Joel,
                                  Have you seen this other thread?
                                  http://www.adobeforums.com/webx/.3bbf275d.3c064bf7/12
                                  ...might help.
                                  Ole
                                  • 14. Re: CreateObject() with ID CS2 broken in Vista (VBA)?
                                    Level 1
                                    Ole,
                                    I read the posts at the link you provided, and now I am trying to re-register my .tlb file with regtlb.exe, but I keep getting an "Invalid Library name specified". I am running it from the command line with Administrator privileges.
                                    Any ideas?
                                    jdb
