10 Replies Latest reply on Jun 26, 2008 9:55 AM by Harbs.
    [CS3][JS] Uniquely identifying documents with common names - possible?
    Andreas Jansson Level 2
      Hi!
      Is there no way to refer directly to a document in app.documents when there are several documents with the same name open at the same time (located in different folders)?
      I have tried to assign unique labels to the documents when opening them, but have not succeeded in referring to documents by their labels, only by name - and the name not being unique, I get just one document reference (the first).
      I also tried using the documents.itemByRange function, supposedly returning an array of all documents in the range defined by the parameters sent to the function. However, sending in the same name in the "from" and "to" parameters, returned only one document:
      app.documents.itemByRange('test.indd', 'test.indd').getElements().length
      Result: 1
      //(I would have expected to get both of them)
      // Referring directly by the name:
      app.documents.item('test.indd').getElements().length
      Result: 1
      // Checking the name of the documents by their indexes:
      app.documents.item(0).name
      Result: test.indd
      app.documents.item(1).name
      Result: test.indd
      Do you really have to loop through all open documents and check their fullName to be able to uniquely identify a document if the names are not unique?
      Kind regards,
      Andreas Jansson
        • 1. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
          Peter Kahrel Adobe Community Professional & MVP
          Try this:
          app.documents.everyItem('test.indd').getElements()
          Peter
          • 2. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
            Sorry, that doesn't seem to work either. I do get an array with 2 in length, but the fullName returns the same value for both documents.
            app.documents.everyItem('test.indd').getElements()[0].fullName
            Result: //..... Data/Indesign-test2/test.indd
            app.documents.everyItem('test.indd').getElements()[1].fullName
            (The two open documents are stored in "Indesign-test" and "Indesign-test2" respectively.)
            Just to make sure I checked the fullName by document index, and it still returns the correct path for the other document:
            app.documents[1].fullName
            Result: //..... Data/Indesign-test/test.indd
            Andreas
            • 3. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
              Level 1
              This is a limitation -- I'd call it a bug, but this was done deliberately and works as intended.
              Having more than one document open with the same name is very difficult to deal with -- just about all the staples don't work. I posted an alert about this here:
              http://www.niemannross.com/developer/wiki/index.php?title=InDesign_JS_Object_Model_Documen ts
              The only way to work, I think, is to build an array of full names and use that to index into the documents. But every time you change the order of the documents, you'll need to re-build the index.
              Dave
              • 4. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
                Level 1
                BTW, one justification for the InDesign team to take this position: only two people have run into this in all the time that scripting InDesign has been possible, and we're talking to each other in this topic.
                Dave
                • 5. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
                  Harbs. Level 6
                  Hi Dave,
                  Make that three or four... ;)
                  Kris at Rorohiko created a method to get unique references to two
                  different documents with the same name. It's usable if you have the free
                  APID ToolAssistant version 1.0.44 or higher. (it doesn't need to be
                  licensed...)
                  Here's an excerpt from the reference manual:
                  The get doc GUID function is used as follows:
                  guid =
                  app.callExtension(0x90B6C,10008,document);
                  This function returns a GUID (Globally Unique Identifier) for a
                  document. This is a string of the form
                  {nnnnnnnn-nnnn-nnnnnnnnnnnnnnnnnnnn}
                  where all 'n' stand for a hexadecimal digit.
                  These GUID allow you to work with same-name documents that
                  are concurrently open without getting tangled in the confusion
                  that occurs when using resolve calls.
                  As long as a document is not moved from its original location on
                  disk, it will keep the same GUID. Two documents with the same
                  name but different paths will have different GUID.
                  Opening, closing, (re)saving to the same location will NOT
                  change the GUID.
                  Moving a document to another location will change the GUID.
                  The find open doc by GUID function is used as follows:
                  doc = app.callExtension(0x90B6C,10009,guid);
                  This function retrieves a reference to an already open document
                  based on its GUID string.
                  These GUID strings are unique and persistent and allow
                  persistent references to same-name documents without resolvelike
                  issues (but the documents are meant to be 'unmovable' i.e.
                  they cannot be renamed or moved to another folder). Once the
                  document is open, it can be retrieved via its GUID.
                  HTH,
                  Harbs
                  • 6. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
                    sstanleyau Level 4
                    On 24/6/08 9:44 PM, "Dave Saunders" <member@adobeforums.com> wrote:<br /><br />> only two people have run into this in all the time that scripting InDesign has<br />> been possible<br /><br />I suspect you mean only two have posted here about it. FWIW, you can get<br />around it in AppleScript using a whose clause, although even that method<br />sometimes has to be a bit indirect because of the use of file references for<br />full path and full name.<br /><br /><br />-- <br />Shane Stanley <sstanley@myriad-com.com.au>
                    • 7. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
                      Level 1
                      Aha! I've forced people to out themselves! Maybe we can start a movement!
                      Dave
                      • 8. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
                        Harbs. Level 6
                        You lead, I'll follow.
                        I've found it's just easier to just ask Kris to create a solution to
                        work around any shortcomings in the scripting DOM, though! :) (He's very
                        good at that...)
                        Harbs
                        • 9. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
                          Thanks for all information and ideas.<br /><br />I ended up with a small function to get an open document by its fullPath.<br /><br />function getDocumentByPath(fullPath){<br />     var myFile = new File(fullPath);<br />     var numberOfDocuments = app.documents.length;<br />     var documentIndex = undefined;<br />     <br />     if (numberOfDocuments == 1){<br />          // Only one document (always index 0) open.<br />          documentIndex = 0;<br />     }else if (numberOfDocuments != 0){<br />          // Loop through all open documents and get the index of the one with the path requested.<br />          var fileFullPath = myFile.absoluteURI;<br />          for (var i = 0; i<app.documents.length; i++){<br />               if (File(app.documents[i].fullName).absoluteURI == fileFullPath){<br />                    documentIndex = i;<br />                    break;<br />               }<br />          }<br />     }<br /><br />     return app.documents[documentIndex];<br />}
                          • 10. Re: [CS3][JS] Uniquely identifying documents with common names - possible?
                            Harbs. Level 6
                            Very nice solution.
                            This will only work if you know the full path. The advantage of the
                            method added by APID, is that it will work even if you don't know the
                            file path. If you come up with a way to do that with scripting alone,
                            I'd love to hear it!
                            Harbs
