7 Replies Latest reply: Jul 11, 2008 12:30 AM by Loic_aigon RSS
    JS field validation
    John.Kordas Community Member
      This should be easy but Im missing something.
      Using the simple Hello World example I want an alert to pop up if the content field is empty. Then display the dialog again to the user so they type something into the filed.
      The changes:
      //Create a text edit field.
      var myTextEditField = textEditboxes.add({minWidth:180});
      var myResult = myDialog.show();
      if(myTextEditField.editContents != ""){
      if(myResult == true ){
      //Get the values from the dialog box controls.
      var myString = myTextEditField.editContents;
      }else{
      //User clicked Cancel, so remove the dialog box from memory.
      myDialog.destroy(); }
      }else{
      alert("Please enter some text into the contents field.");
      Now I get the alert but the dialog closes as well. Is it possible to show the alter but not close the dialog?
        • 1. Re: JS field validation
          Harbs. CommunityMVP
          Use a self-calling function to show the dialog again if the field is empty.
          Harbs
          • 2. Re: JS field validation
            Thanks Harbs,
            Do you mean somthing like:
            }else{
            myDialog.show();
            I tried this but it only worked once then the dialog closed on the third click of the ok button.
            • 3. Re: JS field validation
              Loic_aigon Community Member
              function mydialog()
              var mydialog = app.dialogs.add();
              //your dialog creation script
              if(mydialog.show()!= null)
              if(myTextEditField.editContents == "")
              mydialog();
              else
              // doSomethingHere();
              function doSomethingHere()
              //do something;
              mydialog();
              • 4. Re: JS field validation
                Thanks Ioic_aigon,
                working through what you have I get a error Object is undefined:
                function mydialog()
                with(mydialog){
                //Add a dialog column.
                with(dialogColumns.add()){
                //var myTextEditField = textEditboxes.add({editContents:"Hello World!",minWidth:180});
                //Create a number (real) entry field.
                var myPointSizeField = realEditboxes.add({editValue:72});
                b mydialog(); <==== Object is undefined
                else
                //do something;
                mydialog();
                • 5. Re: JS field validation
                  This is also most working it will bring the dialog back up after you click the ok on the alert. The only problem now is the Cancel will not work unless you enter somthing in the text field.
                  function validate(){
                  var myDialog = app.dialogs.add({name:"Simple User Interface Example Script",canCancel:true});
                  with(myDialog){
                  //Display the dialog box.
                  validate();
                  }else{
                  if(myResult == true){
                  var myPointSize = myPointSizeField.editValue;
                  //Remove the dialog box from memory.
                  myDialog.destroy();
                  //Create a new document.
                  var myDocument = app.documents.add()
                  else{
                  myDialog.destroy();
                  validate();
                  • 6. Re: JS field validation
                    Ok to get he above code to work I changed:
                    to
                    if(myResult == true && myTextEditField.editContents == "")
                    If anyone can see anything wrong with the way I've gone about it please leat me know.
                    Cheers.
                    • 7. Re: JS field validation
                      Hi John,
                      The script is on the way !
                      You if con,dition may be simplier :
                      if(myTextEditField.editContents == "") //entry is ""
                      validate();
                      else if(myResult == true) //user entered datas
                      //action here
                      else //implies user clicked cancel
                      myDialog.destroy();
