2 Replies Latest reply on Jun 9, 2006 1:02 PM by jl2000
    Progress bar for FLV
    jl2000 Level 1
      Hi -
      I have a site with some pretty hefty FLV's and I want to show the user that they are loading...the progress bar thing.
      So I used the code right out of the livedocs for "Creating a progress bar for loading FLV files with Actionscript". I used it with their sample FLV and with my FLV and got the same result. I saw a progress bar and percent text, I heard the audio, but no video. Can anyone help me either fix the livedoc code or use some other to get this to work??
        • 1. Re: Progress bar for FLV
          injpix Level 3
          “…but no video.”
          Ok. From the beginning;
          1. CTRL+L to open up the library panel.
          2. On the very top right corner there is an icon. Click on it.
          3. A menu will appear and then select “New Video”.
          4. Drag this instance from the library onto the stage.
          5. Give it an instance name of “my_video”
          6. Put the code from the livedocs into frame one.
          That should work. If you can actually compile the code with nothing on stage and you can hear the audio from that FLV. So that means you don’t have a Video instance on stage or incorrect instance name. Good luck.
          • 2. Re: Progress bar for FLV
            jl2000 Level 1
            myIP - Bingo.
