4 Replies Latest reply on Jun 6, 2006 1:54 PM by Newsgroup_User
    cleaning up my styles
    kapowd Level 1
      Hello,
      I am trying to clean up my stylesheets for a site I am making and I am having trouble seeing results. I have created a gang of styles that are refered to all over my html. I want to go through and clean up my code because I don't think half of the references do anything. I have a couple of questions about this process:
      If I delete a class and its rules from my remote css folder and save it to the remote server, should all of the pages update? If so, when? I delete a class, refresh my site and there is still the reference to the class in the source code. Even if the class is non existant.
      Is there a quick was in Dreamweaver to check and see what style is effecting what on my pagees?
      I want to clean house but I feel like I am not seeing results on the live site so I am hesitant to keep screwing around.
      You can see my site at www.francistannahill.com/startmeup.htm
      Any advice would be nice.
        • 1. Re: cleaning up my styles
          Level 7
          > the
          Huh? If you delete a class (rule) and its styles from your local CSS file,
          and then upload that file, yes, all pages will reflect that. In other
          words, if I have a rule -
          .myclass { color:blue; }
          and I delete that rule from my stylesheet, then that page (and any others
          using that class rule) will no longer reflect that rule's effect.
          > I delete a class,
          > source
          Yes. That's correct. By deleting the rule from the stylesheet, you have
          not deleted its use from the pages, you have simply made its effect go away.
          > effecting
          > what on my pagees?
          Find and Replace.
          That's certainly alot of custom classes for such a simple page....
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "kapowd" <webforumsuser@macromedia.com> wrote in message
          news:e64f43$hh9$1@forums.macromedia.com...
          > Hello,
          > having
          > to
          > don't
          > about
          > this process:
          > the
          > class,
          > source
          > effecting
          > what on my pagees?
          > site
          > Thanks
          • 2. Re: cleaning up my styles
            GJSallese Level 1
            This may be a silly question but are you refreshing your live site?
            HTH,
            Jerry
            • 3. Re: cleaning up my styles
              kapowd Level 1
              Hey Ace,
              Thanks again for your help.
              So I have to manually remove the html from unused styles? I delete them from my stylesheet, then use find and replace to locate everywhere that class, id whatever shows up. Then I delete all them.
              I should do all this locally and then push it up? If I do that will all the things that I just got rid of locally still be on the remote site?
              Sorry if I am just repeating what you just told me, I just want to be sure.
              And Jerry, I have been refreshing but that is not a silly question. It seems like more times than not, the answer is that simple.
              • 4. Re: cleaning up my styles
                Level 7
                > from
                > id
                Well, assuming you know what to delete, yes.
                > the
                If you upload the edited files, then the edited files will be present both
                locally and remotely.
                > sure.
                No problem.
                news:e64ois$ah$1@forums.macromedia.com...
                > Hey Ace,
                > from
                > id
                > the
                > sure.
                > seems
