• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Rename files name
Guest
Jun 06, 2006 Jun 06, 2006
Hi All,
I am having a merged project, that contain several books that have the same topic name (for example: I have introduction topic on each book in the merged project), and the problem is that from theses pages clicking on any links wil transfer to the rigth place but when I am clicking on the back button I will get the place I was before on the right pane, but in the left pane (help tree) I am placed in another book
So what i am thinking to do is changing all the names of each HTML files (in each book separately) that will contain the book name, but now the projects does not recognize those files
How can I connect to the new name??
Thanks you all, and have anice day
Views
507
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Jun 07, 2006 Jun 07, 2006
Are you renaming in Windows Explorer? Will not work, must be done via project.
Have you republished all projects?
Votes
Translate
Translate
Report
Report
Guest
Yes i changed the files name in the Windows Explorer,
How can i change all the files name via project ??
Thanx
Votes
Translate
Translate
Report
Report
Community Expert ,
Well first you are going to have to put them back to their original names in Windows Explorer so that the project recognises them.
Then in RH there are various ways. In Project Manager use View by File Name and click the file name. In the topics tab, right click the topic and select properties. Open the topic, right click over it and select properties.
Votes
Translate
Translate
Report
Report
Guest
Thank, I allredy knows this option.
but the problem is that i have to change somthing like 150 files in each project ,
so it will take me alot of timeto do it manually (actually i used the multi- rename tool in the Total comander)
mabe you can recommend me another way to rename alot of files together ?? ( i just want to add to all of those files 3 letters)
Votes
Translate
Translate
Report
Report
Community Expert ,
Total comander???
No easy solution that I can think of. Don't forget, that doing this will break cross project links.
I am surprised with what you found that the sync issue only occurs with CHM projects. Maybe better to focus on the problem than this solution?
Votes
Translate
Translate
Report
Report
Guest
The Total Comander is an explorer tool .
Its work before becouse in each sepered book i dont have duplicity files, its happened only in the mereged project becouse each book in my mereged project contain several topics with the same file name (for example : "introduction.htm-- this file repeat on himself in each book suitability. and all the commands reapet on them in each separate book)
i dont know what to do
maybe you can direct me ?
Votes
Translate
Translate
Report
Report
Community Expert ,
I wish I could. As I explained (to you?)in another thread, having more than one file with the same name in different projects does not cause the auto syncing of of the TOC to go wrong in webhelp. The failure of autosyncing in merged CHM help is your real problem.
My gut feel is your real problem is something to do with the merge set up and the duplicate file names is a red herring.
Votes
Translate
Translate
Report
Report
Guest
LATEST
OK,
Thank you very much for your patience, supporting me
Bye have agreat day
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
