4 Replies Latest reply on May 19, 2006 6:30 AM by Newsgroup_User
    associative array
    techy2001 Level 1
      hi,
      i have some simple questions-
      1.what is the advantage of using Object constructor to create an associative array over using an Array constructor to create an associative array??
      2.What is difference between using a dot over array access syntax .whats the advantage of one over other??basically where to use which one.
      3.how can i find the length of an associative array
      thanks
      waiting for answers
        • 1. Re: associative array
          Level 7
          techy2001,
          How do you know they're simple?
          The Array class extends the Object class, so ultimately, an instance of
          either class is an Object instance. I don't know that there's really an
          advantage to using one over the other. If you instantiate an Object object
          and add properties to it, you conceptually have an "associative array," but
          you certainly don't have an Array instance -- so you don't have the
          Array.length property; you don't have any of the Array class methods, etc.
          If you instantiate an Array object and populate it with Object objects,
          you'll have access to the Array class members. Only you will know if those
          are benefits or not.
          Dot syntax may be used when you know the name of the property in
          question. The array access operator may be used when you need to "drill
          down" to a property dynamically, because, for example, you wish to refer to
          dozens of sequentially named properties. The array access operator, [],
          simply resolves strings to object references.
          See this article for details on using the array access operator in this
          scenario.
          http://www.quip.net/blog/2006/flash/actionscript-20/reference-objects-dynamically
          If your "associative array" is an Array instance, you reference its
          Array.length property. If your "associative array" is simply an object of
          objects, you would have to cycle through it with, say, a for..in statement
          and count the properties yourself.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: associative array
            There are two advantages to using an Object instance for an associative array. First, you can use an object literal to define the associative array. For example:
            var foo:Object = {prop1: "value1", prop2: "value2"};
            Second, it avoids any unexpected behavior resulting from the mixture of indexed and associative arrays. For example, the following code provides unexpected results because it mixes the two concepts:
            var arr:Array = new Array();
            arr.foo = "foo";
            arr.bar = "bar";
            arr.push("foobar");
            trace(arr.length); // output: 1
            The length property only considers elements in an indexed array (e.g. arr[0] ), and ignores any elements that are attached as properties (e.g. "foo" and "bar").
            It's better not to mix the two types of arrays, so I recommend that you use the Object class for associative arrays, and the Array class for indexed arrays.
            • 3. Re: associative array
              Level 7
              You've made some major errors David !!
              >> I don't know that there's really an advantage to using one over the
              >> other.
              The disadvantage is that if you use the Array class for your associative
              then you may well think that you can use Array methods on it .. you can't.
              You can only use the methods defined in Object class
              No you won't ... and that is EXACTLY why you shouldn't do it .. because if
              David Stiller can be confused bout this, what hope do mere mortals have !!
              There is no advantage to either method except that the [ ] array syntax lets
              you do things that the dot method doesn't (eg use expresions as varaible
              names and use names that do mot match the usual rules for variables)
              If you can do it with '.' dot syntax, then there is no advantage or
              disadvatnage to the [ ] array syntax as they compile to identical code
              NO !!!!!!!!!!!!!!!!!!!! you CANNOT use the length property at all.
              You HAVE to iterate thru (using a for/in loop) to get the length
              Jeckyl
              • 4. Re: associative array
                Level 7
                Jeckyl,
                Bring it on! :-p
                >> Object objects, you'll have access to the Array class
                >> members.
                > do it .. because if David Stiller can be confused bout this,
                LOL Dude, I am constantly in awe of your Flash prowess -- have been for
                years. It is I, dear fellow, who am the mortal. I'm still trying to make
                sense out of ActionScript (and programming in general), and loving every
                minute of it. It's a good point you bring up, though. I'm glad you mention
                it, because I see now what I've done to muddy the waters.
                To my incorrect thinking, an associative array could be represented like
                this:
                var aa:Array = new Array();
                aa.push({tick:"tick"});
                aa.push({tack:"tack"});
                aa.push({toe:"toe"});
                ... in which case, of course, the Array.length property holds. The more I
                thunk on it, though, the more I realized the above isn't an associative
                array at all. It's just an indexed array with object elements. That's
                where I went wrong.
                Consulting the ActionScript 2.0 Language Reference (I'm a fan), I see
                "Note: There is no advantage to using the Array constructor to create an
                associative array. The Array constructor is best for creating indexed
                arrays" (Creating associative arrays).
                In that same section, the instructions for creating an associative array
                show exactly what you've mentioned. My apologies to all.
                And thanks to Jeckyl!
                David
