11 Replies Latest reply on Nov 5, 2008 12:48 AM by Newsgroup_User
    FW CS3 - how to export multiple panel headers?
    Level 7
      I have typical web diesign issue but it seems that it is difficult or even
      imposible to achieve with FW CS3. Maybe somebody can help me.
      I have to create 2 sets of headers (title + background) for 2 graphic
      panels. First set of headers (for first panel) cosist of 6 variants. Second
      set contains only 2 variants. It is important to keep position of both
      groups of headers becouse background underneath them is different and
      headers are semi-transparent. Each of variant of headers is kept on separate
      frame. In this case, if 6 frames is created then 6*2=12 files will be
      exported but I need only 8. Of course I could remove unexpected files by
      hand but real project is large and number of unexpected files is about
      100!!! It is almost impossible to keep in mind what files should be
      removed.
      Is any way to create as many files as I need?
      Regards,
      Marek
        • 1. Re: FW CS3 - how to export multiple panel headers?
          Level 7
          Marek wrote:
          > Hi,
          > removed.
          > Regards,
          > Marek
          Rather than using frames, this might be better accomplished by having
          each header on a separate page in Fireworks, assuming you have FW CS3 or
          higher. A link to the png file might also help us be more specific.
          Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
          http://www.communityMX.com/
          CommunityMX - Free Resources:
          http://www.communitymx.com/free.cfm
          .:Adobe Community Expert for Fireworks:.
          http://tinyurl.com/2a7dyp
          .:Author:.
          Lynda.com - http://movielibrary.lynda.com/authors/author/?aid=188
          Peachpit Press -
          http://www.peachpit.com/authors/bio.aspx?a=d98ed798-5ef0-45a8-a70d-4b35fa14c9a4
          Layers Magazine - http://www.layersmagazine.com/author/jim-babbage
          • 2. Re: FW CS3 - how to export multiple panel headers?
            Level 7
            H Jim,
            > Rather than using frames, this might be better accomplished by having each
            Yes, that is true but in this treatment it is necessary to place slices on
            each page separately. When cutting lines changes its locations (which is
            typical during developing process) it is necessary to go page by page and
            shift and resize slices. I would prefer keep slices on one page to avoid
            problems with relative positioning slices spreaded through many pages.
            By the way... do you know whether FW CS4 has solution for this typical
            issue? I'm expecting either slice resizing/relocation through many pages or
            something like multistate symbols having one slice and producting many
            files.
            • 3. Re: FW CS3 - how to export multiple panel headers?
              Level 7
              Marek wrote:
              > H Jim,
              > files.
              Well don't see any quick answer to your problem if each slice needs to
              be a custom size. It might be more clear if we had an example of what
              you are trying to achieve.
              If I am misreading your post and indeed, all the slices DO need to be
              the same size, one other option would be to place the slice template on
              a master page, and have your designs (again) on separate pages. This can
              solve the issue of "slice resizing/relocation through many pages..."
              Multistate symbols - button symbols for example - only use the same
              slice for each state. For that matter, if you place a slice over an area
              that has several different states, you will get a slice from each
              state/frame. Just make sure to "export selected slice(s) only", so you
              don't get a bunch of grahics you don't want.
              There has been no significant change to how slices are utilized in CS4.
              My apologies if I am not "getting" what you are trying to do.
              .:Author:.
              Peachpit Press -
              • 4. Re: FW CS3 - how to export multiple panel headers?
                Level 7
                Ok, take a look http://lifekauf.de/test.png
                After exporting this file you will get 4 headers of panel 1 and 2 headers of
                panel 2. There are no unneeded files exported.
                I used the button symbol to achieve it. Unfortunately only up to 4 states of
                headers I can export using this symbol. Take a look on slices construction.
                When I decide to resize any panel I can easly fix slice border by shifting
                vertical line between slice p1 and panel 1 and horizontal line between p0
                and panel 1. If your idea will be implemented where all header will be on
                separate page then every change to the layout requires correction of
                size/position slices page by page. It is hard then to keep slices on one
                page fitting to slices used on other pages.
                • 5. Re: FW CS3 - how to export multiple panel headers?
                  Level 7
                  I will try to review this over the weekend, time permitting.
                  .:Author:.
                  Peachpit Press -
                  • 6. Re: FW CS3 - how to export multiple panel headers?
                    Level 7
                    >> headers of panel 2. There are no unneeded files exported.
                    >> states of headers I can export using this symbol. Take a look on
                    >> slices construction. When I decide to resize any panel I can easly fix
                    >> slice border by shifting vertical line between slice p1 and panel 1
                    >> and horizontal line between p0 and panel 1. If your idea will be
                    >> implemented where all header will be on separate page then every
                    >> change to the layout requires correction of size/position slices page
                    >> by page. It is hard then to keep slices on one page fitting to slices
                    As I understand it, you have two issues here:
                    1) you want to resize a slice across multiple pages
                    2) You want to have a different number of frames/states for certain
                    slices on different pages.
                    Solution for # 1: Put your slices on a web SUB LAYER and share that
                    layer across the pages you want to have common slicing for. This layer
                    only needs to be created once. Then, when you resize the slice, it will
                    resize on all pages sharing the web sublayer.
                    Solution for # 2: Add your frames/states to the pages you need them.
                    Select a slice and right-click on the slice. Choose Export Selected
                    Slice. Deselect Current Frame only (and possibly Current page)in the
                    export menu. Export your slices.
                    This works fine in CS4 and CS3 with one notable exception; in both
                    applications, the original slice name is ignored, and Fireworks exports
                    the frames/states based on the page name.
                    Example:
                    original slice name: panel_top
                    final graphic name(s): page 1.gif, page 1_f2.gif, page 1_f3.gif etc . ..
                    I have not had time yet to try out exporting multiple selected slices to
                    see what happens to the file names. Will try to make time to do that
                    tonight.
                    HTH
                    .:Author:.
                    Peachpit Press -
                    • 7. Re: FW CS3 - how to export multiple panel headers?
                      Level 7
                      Not necessarily - generarlly I would like to have access to slice editing.
                      It is hard to fit slices across pages because I can't show on one page
                      posiotion of slices placed on another one (excluding master page slices
                      which are unusefull because produces files on each page - even on those
                      which don't contain graphics for use on web page).
                      > 2) You want to have a different number of frames/states for certain slices
                      > on different pages.
                      The only thing I would like to achieve is to have possibility of creation of
                      unpredictable number of panel headers (customers can request more headers in
                      later time). I can't use separate slices for each version of panel header
                      because all headers looks good only particular place in graphic design. Note
                      that I want to avoid producing unusefull files which would be generated when
                      frames are used.
                      > Solution for # 1: Put your slices on a web SUB LAYER and share that layer
                      > across the pages you want to have common slicing for. This layer only
                      > needs to be created once. Then, when you resize the slice, it will resize
                      It could be solution but I can't see any option allowing to share or not
                      sublayer. Do you mean to use master page to share slice(s) among pages?
                      > Select a slice and right-click on the slice. Choose Export Selected Slice.
                      > Deselect Current Frame only (and possibly Current page)in the export menu.
                      > Export your slices.
                      Hmmm... this is also solution but very risky. Notice that state of option
                      "current frame only" is not remembered and I'm afraid that one careless
                      export can produce hundreds of files hard to select and remove, especially
                      when destination folder contains many other files.
                      > Example:
                      > tonight.
                      No no ... it works fine. The slice names are used.
                      • 8. Re: FW CS3 - how to export multiple panel headers?
                        Level 7
                        BTW
                        Fireworks before MX version had very usefull functionality. It was possible
                        define as many frames as needed and define on slice level which frames
                        should be exported for this particular slice. In typical project most of
                        slices was set to only first frame. Panels headers, rollovers etc was set to
                        more exported frames.
                        When I moved old projects to CS3 I received a lot of unneeded files after
                        exporting.
                        I'm trying to "simulate" lost very usefull functionality of FW. Mentioned
                        above option still exists in CS3 but seems not working. In Frames panel
                        double click on field having time units. New dialog box appears with
                        checkbox "include when exporting". Functionality was limited to animations
                        only.
                        • 9. Re: FW CS3 - how to export multiple panel headers?
                          Level 7
                          Hi Marek:
                          As I said in solution one, you must create a WEB sub layer. You cannot
                          share a main web layer to other pages, but you can share a web sub layer
                          to other pages. Select the web layer on a page and then create a new
                          sublayer OF the web layer. Then choose Share Layer to Pages from the
                          Layer options menu. Add your slices to that web sub layer. Then the one
                          set of slices become common to all pages you choose to share the web sub
                          layer with.
                          If you need different slice dimensions on each page, that won't work,
                          and you will have to have independent slices on each page, as you
                          probably do now.
                          As for the other risk, well, you will just have to be careful of what
                          you do. Sounds a bit trite, I know, but that's all I can think of, other
                          than using a new folder for those exports.
                          If you do accidentally export to many graphics, yuo can always sort by
                          time and delete them, then re export and ensure the proper options are
                          selected or deselected.
                          >> on different pages.
                          > frames are used.
                          >> Export your slices.
                          >> Example:
                          >> tonight.
                          .:Author:.
                          Peachpit Press -
                          • 10. Re: FW CS3 - how to export multiple panel headers?
                            Level 7
                            Marek wrote:
                            > BTW
                            > exporting.
                            > only.
                            My recommendation is to add your request to the Adobe wish list; maybe
                            they can reinstate this feature, unless there was some functional reason
                            why it was removed. There were many changes when FW moved from FW 4 to
                            FW MX; it's even possible the feature got lost in the shuffle.
                            .:Author:.
                            Peachpit Press -
                            • 11. Re: FW CS3 - how to export multiple panel headers?
                              Level 7
                              Hi Jim again,
                              > sublayer OF the web layer. Then choose Share Layer to Pages from the Layer
                              > options menu. Add your slices to that web sub layer. Then the one set of
                              > slices become common to all pages you choose to share the web sub layer
                              > with.
                              Sorry for my delay in response, I live in different time zone :-)
                              I have just discovered the option mentioned above and tested it. I had to be
                              blind...
                              There is a result of my test. Shared slices force the same its name on every
                              page. So when I export page 2 it overwritting common slices exported from
                              page 1 and so on. It is very easy to lost control on what we really want to
                              do, especially when we have a lot of projects and every one of them needs
                              special treatment. Conclusion is that sharing layers is good functionality
                              for sharing graphics - not slices.
                              Anyway - thanks for your help. I will try to send feature request to Adobe
                              what I have already done a couple of times...
