15 Replies Latest reply on Jun 24, 2008 12:42 AM by (Russell_C_Taylor)
    BlazeDS FlashDevelop RPC ArrayList
      Hi,<br /><br />I've managed to get RPC working with BlazeDS and FlashDevelop using pure actionscript 3 & rpc.swc.  Great, I can return strings & booleans from the my java objects.<br /><br />I've tried some tutes and the BlazeDS developers guide to try and create custom serialization.  But I am stuck with - ArgumentError: Error #2004: One of the parameters is invalid.  When I try to return an ArrayList?<br /><br />The developers guide says it's possible to associate the java ArrayList with mx.collections.ArrayCollection.  I've tried several methods but so far just get the above error.  <br /><br />Here's the ArrayList<IdeaRO> that I'm trying to serialize;<br /><br />package tbi.DAO;<br /><br />//import java.util.Vector;<br />import java.io.Externalizable;<br />import java.io.IOException;<br />import java.io.ObjectInput;<br />import java.io.ObjectOutput;<br /><br />/**<br /> * <br /> * @author Russell Taylor<br /> * @created 13.06.2008<br /> * <br /> * This result object contains relates to each Idea Touch Point<br /> * and can also be used the Ideas in the related scroll component<br /> *<br /> */<br />public class IdeaRO implements Externalizable {<br />     <br />     private int _id;<br />     private String _title;<br />     private String _imageUrl;<br />     private int _level;<br />     private int _plusScore;<br />     private int _minusScore;<br />     <br />     /**<br />      * BlazeDS needs this to instantiate<br />      */<br />     public IdeaRO(){<br />          <br />     }<br />     <br />     public int getId(){<br />          return _id;<br />     }<br />     <br />     public void setId(int value){<br />          this._id = value;<br />     }<br />     <br />     public String getTitle(){<br />          return _title;<br />     }<br />     <br />     public void setTitle(String value){<br />          this._title = value;<br />     }<br />     <br />     public String getImageURL(){<br />          return _imageUrl;<br />     }<br />     <br />     public void setImageURL(String value){<br />          this._imageUrl = value;<br />     }<br />     <br />     public int getLevel(){<br />          return _level;<br />     }<br />     <br />     public void setLevel(int value){<br />          this._level = value;<br />     }<br />     <br />     public int getPlusScore(){<br />          return _plusScore;<br />     }<br />     <br />     public void setPlusScore(int value){<br />          this._plusScore = value;<br />     }<br />     <br />     public int getMinusScore(){<br />          return _minusScore;<br />     }<br />     <br />     public void setMinusScore(int value){<br />          this._minusScore = value;<br />     }<br />     <br />     /**<br />     * Serializes the server state of an instance of ThirdPartyProxy<br />     * by sending a String for the name, a Map of properties<br />     * String for the description, and a floating point<br />     * integer (single precision) for the price. Notice that the inventory <br />     * identifier is not sent to external clients.<br />     */<br />    public void writeExternal(ObjectOutput out) throws IOException {<br />        // Write out the client properties from the server representation<br />        out.writeFloat(_id);<br />        out.writeObject(_title);<br />        out.writeObject(_imageUrl);<br />        out.writeFloat(_level);<br />        out.writeFloat(_minusScore);<br />        out.writeFloat(_plusScore);<br />    }<br />    <br />    /**<br />     * Deserializes the client state of an instance of ThirdPartyProxy<br />     * by reading in String for the name, a Map of properties<br />     * for the description, and <br />     * a floating point integer (single precision) for the price. <br />     */<br />    public void readExternal(ObjectInput in) throws IOException,<br />        ClassNotFoundException {<br />        // Read in the server properties from the client representation.<br />        _id = (int)in.readFloat();<br />        _title = (String)in.readObject();<br />        _imageUrl = (String)in.readObject();<br />        _level = (int)in.readFloat();<br />        _minusScore = (int)in.readFloat();<br />        _plusScore = (int)in.readFloat();<br />        <br />    }<br /><br />}<br /><br />Any help would be appreciated.<br /><br />Thanks,<br /><br />Russell
        • 1. Re: BlazeDS FlashDevelop RPC ArrayList
          Peter Farland Pioneer
          Make sure mx.collections.ArrayList is linked into your SWF so that it is
          available at runtime. You just need to import this class and make a
          reference to it somewhere so that it gets compiled into the SWF.
          • 2. Re: BlazeDS FlashDevelop RPC ArrayList
            Newcomer
            Thanks for the quick response :)<br /><br />I have mx.collection.ArrayList included (Flex 2 source framwork globalpath).  But I think I'm missing a trick.  I've read that LCDS has problems serializing a custom ArrayList and returns null?  My ArrayList is in java is a standard arraylist of custom objects. ie. ArrayList<IdeaRO>.<br /><br />Here's my test connection class in case I'm doing something wrong;<br /><br />package dao <br />{<br />     import flash.net.NetConnection;<br />     import flash.net.Responder;<br />     import flash.net.ObjectEncoding;<br />     import flash.events.*;<br />     import flash.text.*;<br />     import flash.display.*;<br />     import xml.XMLProxyModel;<br />     import mx.collections.ArrayList;<br />     import dao.IdeaRO;<br />     <br />     /**<br />     * ...<br />     * @author Russell Taylor<br />     */<br />     public class ConnectionHelper extends Sprite<br />     {<br />          private var gateway:String = XMLProxyModel.getInstance().amfChannel;<br />          private var con:NetConnection;<br />          private var responder:Responder;<br />          private var tf:TextField;<br />          <br />          public function ConnectionHelper() <br />          {<br />               <br />               responder = new Responder(onResult, onFault);<br />               <br />               con = new NetConnection();<br />               NetConnection.defaultObjectEncoding = ObjectEncoding.AMF3;<br />               <br />               con.addEventListener(NetStatusEvent.NET_STATUS, onStatus);<br />               con.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);<br />               <br />               con.connect(gateway);<br /><br />               <br />               con.call("tbi.getSphinxArray", responder);<br /><br />          }<br />          <br />          private function onStatus(event:NetStatusEvent = null):void<br />          {<br />               traceField("NetStatus="+String(event.info.code));<br />          }<br />          <br />          private function securityErrorHandler(event:SecurityErrorEvent = null):void<br />          {<br />               traceField("Security Error=" + event);<br />          }<br />          <br />          private function onResult(result:Object):void<br />          {<br />               var resultSet:ArrayList = ArrayList(result);<br />               traceField("Result=" + String(resultSet));<br /><br />          }<br />          <br />          private function onFault(fault:Object=null):void<br />          {<br />               traceField("Fault="+String(fault.message));<br />          }<br />          <br />          private function traceField(txt:String):void<br />          {<br />               if(tf == null){<br />               tf = new TextField();<br />               tf.background = true;<br />               tf.backgroundColor = 0xFFFFFF;<br />               tf.width = 500;<br />               tf.height = 500;<br />               addChild(tf);<br />               }<br />               tf.appendText(txt);<br />          }<br />          <br />     }<br />     <br />}<br /><br />Can anyone see any glaring mistakes?<br /><br />Thanks.
            • 3. Re: BlazeDS FlashDevelop RPC ArrayList
              Importing something is not enough, you need to make a reference to it by<br />using the type for a variable, method signature, whatever... e.g. try<br />adding a dummy variable:<br /> <br />private static var dep:IdeaRO;<br /><br />________________________________<br /><br />From: Russell C Taylor [mailto:member@adobeforums.com] <br />Sent: Monday, June 23, 2008 9:33 AM<br />To: blazeds-gettingstarted@adobeforums.com<br />Subject: Re: BlazeDS FlashDevelop RPC ArrayList<br /><br /><br />A new message was posted by Russell C Taylor in <br /><br />Configuration and Getting Started Discussion --<br />  BlazeDS FlashDevelop RPC ArrayList<br /><br />Thanks for the quick response :) <br /><br />I have mx.collection.ArrayList included (Flex 2 source framwork<br />globalpath). But I think I'm missing a trick. I've read that LCDS has<br />problems serializing a custom ArrayList and returns null? My ArrayList<br />is in java is a standard arraylist of custom objects. ie.<br />ArrayList<IdeaRO>. <br /><br />Here's my test connection class in case I'm doing something wrong; <br /><br />package dao <br />{ <br />import flash.net.NetConnection; <br />import flash.net.Responder; <br />import flash.net.ObjectEncoding; <br />import flash.events.*; <br />import flash.text.*; <br />import flash.display.*; <br />import xml.XMLProxyModel; <br />import mx.collections.ArrayList; <br />import dao.IdeaRO; <br /><br />/** <br />* ... <br />* @author Russell Taylor <br />*/ <br />public class ConnectionHelper extends Sprite <br />{ <br />private var gateway:String = XMLProxyModel.getInstance().amfChannel; <br />private var con:NetConnection; <br />private var responder:Responder; <br />private var tf:TextField; <br /><br />public function ConnectionHelper() <br />{ <br /><br />responder = new Responder(onResult, onFault); <br /><br />con = new NetConnection(); <br />NetConnection.defaultObjectEncoding = ObjectEncoding.AMF3; <br /><br />con.addEventListener(NetStatusEvent.NET_STATUS, onStatus); <br />con.addEventListener(SecurityErrorEvent.SECURITY_ERROR,<br />securityErrorHandler); <br /><br />con.connect(gateway); <br /><br /><br /><br />con.call("tbi.getSphinxArray", responder); <br /><br />} <br /><br />private function onStatus(event:NetStatusEvent = null):void <br />{ <br />traceField("NetStatus="+String(event.info.code)); <br />} <br /><br />private function securityErrorHandler(event:SecurityErrorEvent =<br />null):void <br />{ <br />traceField("Security Error=" + event); <br />} <br /><br />private function onResult(result:Object):void <br />{ <br />var resultSet:ArrayList = ArrayList(result); <br />traceField("Result=" + String(resultSet)); <br /><br />} <br /><br />private function onFault(fault:Object=null):void <br />{ <br />traceField("Fault="+String(fault.message)); <br />} <br /><br />private function traceField(txt:String):void <br />{ <br />if(tf == null){ <br />tf = new TextField(); <br />tf.background = true; <br />tf.backgroundColor = 0xFFFFFF; <br />tf.width = 500; <br />tf.height = 500; <br />addChild(tf); <br />} <br />tf.appendText(txt); <br />} <br /><br />} <br /><br />} <br /><br />Can anyone see any glaring mistakes? <br /><br />Thanks. <br /><br /><br />________________________________<br /><br />View/reply at BlazeDS FlashDevelop RPC ArrayList<br /><a href=http://www.adobeforums.com/webx?13@@.59b59dad/1> <br />Replies by email are OK.<br />Use the unsubscribe<br /><a href=http://www.adobeforums.com/webx?280@@.59b59dad!folder=.3c061a84>  form<br />to cancel your email subscription.
              • 4. Re: BlazeDS FlashDevelop RPC ArrayList
                Newcomer
                Thanks again Peter. I tried your suggestion but the application error is still there.
                I suspect it is related to BlazeDS inability to seriliaze my ArrayList. I have read the BlazeDS developers guide but I am stuck trying to correctly externalize an ArrayList in both Java and actionscript.
                Any examples would be appreciated:)
                Thanks again. So close yet so far!
                • 5. Re: BlazeDS FlashDevelop RPC ArrayList
                  Newcomer
                  The reason for my thinking above is an unhandled argumenterror Error #2004 - One of the parameters is invalid. Which is thrown by the Flash 9 debugger.
                  I only get this problem with an ArrayList. I've tried other data types, all were successful.
                  Thanks in advance for even the smallest pin-***** at the end of the tunnel :)
                  • 6. Re: BlazeDS FlashDevelop RPC ArrayList
                    Newcomer
                    Here's the method that creates the ArrayList I wish to parse to the client.<br /><br />/**<br />      *  Search results method parses the HashMap<br />      *  and returns a result list collection<br />      *  <br />      *  @param ids HashMap<String, int[]><br />      *  <br />      *  @return List collection of results<br />      */<br />     public static ArrayList<IdeaRO> getSphinxArray(HashMap<String, int[]> ids) throws SQLException{<br />          ArrayList<IdeaRO> list = new ArrayList<IdeaRO>();<br />          Connection c = null;<br />          <br />               try{<br />                    c = ConnectionHelper.getConnection();<br />                    Statement s = c.createStatement();<br />                    for (Iterator<Map.Entry<String, int[]>> entry=ids.entrySet().iterator(); entry.hasNext();){<br />                         Map.Entry<String, int[]> key = (Map.Entry<String, int[]>)entry.next();<br />                         for(int id:key.getValue()){<br />                              ResultSet rs = s.executeQuery("SELECT `tbi_db_test`.`post`.`title`, `tbi_db_test`.`link`.`url`, `tbi_db_test`.`levelindicator`.`level`, `tbi_db_test`.`scorerelation`.`score_plus`, `tbi_db_test`.`scorerelation`.`score_minus` FROM `tbi_db_test`.`post` JOIN tbi_db_test.link ON tbi_db_test.post.post_id=tbi_db_test.link.post_id_fk JOIN tbi_db_test.levelindicator ON tbi_db_test.post.post_id=tbi_db_test.levelindicator.post_id_fk JOIN tbi_db_test.scorerelation ON tbi_db_test.post.post_id=tbi_db_test.scorerelation.post_id_fk WHERE tbi_db_test.post.post_id="+(int)id);<br />                              while(rs.next()){<br />                                   IdeaRO result = new IdeaRO();<br />                                   result.setId((int)id);<br />                                   result.setTitle(rs.getString("title"));<br />                                   result.setImageURL(rs.getString("url"));<br />                                   result.setLevel(rs.getInt("level"));<br />                                   result.setPlusScore(rs.getInt("score_plus"));<br />                                   result.setMinusScore(rs.getInt("score_minus"));<br />                                   list.add(result);<br />                              }<br />                         }<br />                    }<br />               }finally{<br />                    c.close();<br />               }<br /><br />          return list;<br />     };
                    • 7. Re: BlazeDS FlashDevelop RPC ArrayList
                      <DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2>Oh sorry, I thought you were talking about <br />flex.messaging.io.ArrayList (Server) / mx.collections.ArrayList <br />(Client).</FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2></FONT></SPAN> </DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2>You're just asking about the standard java.util.ArrayList <br />collection class. In that case, these are being returned as <br />flex.messaging.io.ArrayCollection instances by default, the equivalent for that <br />class on the client is mx.collections.ArrayCollection. </FONT></SPAN><SPAN <br />class=918365815-23062008><FONT face=Arial color=#0000ff size=2>So.... you would <br />need to ensure mx.collections.ArrayCollection is linked into your SWF in the <br />manner described earlier.</FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2></FONT></SPAN> </DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2>Or.... you can change the BlazeDS endpoint <br />serialization setting "legacy-collection" to true to get it to return <br />ActionScript Arrays for Java Collections. See:</FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2></FONT></SPAN> </DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2><A <br />href="http://livedocs.adobe.com/blazeds/1/blazeds_devguide/help.html?content=serialize_ data_3.html">http://livedocs.adobe.com/blazeds/1/blazeds_devguide/help.html?content=serial ize_data_3.html</A></FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2></FONT></SPAN> </DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2>i.e.</FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2></FONT></SPAN> </DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff size=2>        <br />&lt;channel-definition id="my-amf" <br />class="mx.messaging.channels.AMFChannel"&gt;<BR>            <br />&lt;endpoint url="<A <br />href="http://{server.name}:{server.port}/{context.root}/messagebroker/amf">http://{serv er.name}:{server.port}/{context.root}/messagebroker/amf</A>" <br />class="flex.messaging.endpoints.AMFEndpoint"/&gt;<BR>            <br />&lt;properties&gt;<BR>                <br />&lt;polling-enabled&gt;false&lt;/polling-enabled&gt;</FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff <br />size=2>                &lt;serialization&gt;</FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff <br />size=2>                    <br />&lt;legacy-collection&gt;true&lt;/legacy-collection&gt;</FONT></SPAN></DIV><br /><DIV dir=ltr align=left><SPAN class=918365815-23062008><FONT face=Arial <br />color=#0000ff <br />size=2>                <br />&lt;/serialization&gt;<BR>            <br />&lt;/properties&gt;<BR>        <br />&lt;/channel-definition&gt;<BR></DIV></FONT></SPAN><BR><br /><DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><br /><HR tabIndex=-1><br /><FONT face=Tahoma size=2><B>From:</B> Russell C Taylor <br />[mailto:member@adobeforums.com] <BR><B>Sent:</B> Monday, June 23, 2008 11:38 <br />AM<BR><B>To:</B> blazeds-gettingstarted@adobeforums.com<BR><B>Subject:</B> Re: <br />BlazeDS FlashDevelop RPC ArrayList<BR></FONT><BR></DIV><br /><DIV></DIV>A new message was posted by Russell C Taylor in <br /><BR><BR><B>Configuration and Getting Started Discussion</B> <br />--<BR>  BlazeDS FlashDevelop RPC ArrayList<BR><BR>Here's the method <br />that creates the ArrayList I wish to parse to the client. <BR><BR>/** <BR>* <br />Search results method parses the HashMap <BR>* and returns a result list <br />collection <BR>* <BR>* @param ids HashMap&lt;String, int[]&gt; <BR>* <BR>* <br />@return List collection of results <BR>*/ <BR>public static <br />ArrayList&lt;IdeaRO&gt; getSphinxArray(HashMap&lt;String, int[]&gt; ids) throws <br />SQLException{ <BR>ArrayList&lt;IdeaRO&gt; list = new ArrayList&lt;IdeaRO&gt;(); <br /><BR>Connection c = null; <BR><BR>try{ <BR>c = ConnectionHelper.getConnection(); <br /><BR>Statement s = c.createStatement(); <BR>for (Iterator&lt;Map.Entry&lt;String, <br />int[]&gt;&gt; entry=ids.entrySet().iterator(); entry.hasNext();){ <br /><BR>Map.Entry&lt;String, int[]&gt; key = (Map.Entry&lt;String, <br />int[]&gt;)entry.next(); <BR>for(int id:key.getValue()){ <BR>ResultSet rs = <br />s.executeQuery("SELECT `tbi_db_test`.`post`.`title`, `tbi_db_test`.`link`.`url`, <br />`tbi_db_test`.`levelindicator`.`level`, <br />`tbi_db_test`.`scorerelation`.`score_plus`, <br />`tbi_db_test`.`scorerelation`.`score_minus` FROM `tbi_db_test`.`post` JOIN <br />tbi_db_test.link ON tbi_db_test.post.post_id=tbi_db_test.link.post_id_fk JOIN <br />tbi_db_test.levelindicator ON <br />tbi_db_test.post.post_id=tbi_db_test.levelindicator.post_id_fk JOIN <br />tbi_db_test.scorerelation ON <br />tbi_db_test.post.post_id=tbi_db_test.scorerelation.post_id_fk WHERE <br />tbi_db_test.post.post_id="+(int)id); <BR>while(rs.next()){ <BR>IdeaRO result = <br />new IdeaRO(); <BR>result.setId((int)id); <br /><BR>result.setTitle(rs.getString("title")); <br /><BR>result.setImageURL(rs.getString("url")); <br /><BR>result.setLevel(rs.getInt("level")); <br /><BR>result.setPlusScore(rs.getInt("score_plus")); <br /><BR>result.setMinusScore(rs.getInt("score_minus")); <BR>list.add(result); <BR>} <br /><BR>} <BR>} <BR>}finally{ <BR>c.close(); <BR>} <BR><BR>return list; <BR>}; <br /><BR><BR><br /><HR align=left width=200><br />View/reply at <A href="http://www.adobeforums.com/webx?13@@.59b59dad/5">BlazeDS <br />FlashDevelop RPC ArrayList</A><BR>Replies by email are OK.<BR>Use the <A <br />href="http://www.adobeforums.com/webx?280@@.59b59dad!folder=.3c061a84">unsubscribe</A> <br />form to cancel your email subscription.<BR><BR>
                      • 8. Re: BlazeDS FlashDevelop RPC ArrayList
                        (Resending in plain text)...<br /><br /><br />Oh sorry, I thought you were talking about flex.messaging.io.ArrayList<br />(Server) / mx.collections.ArrayList (Client).<br /> <br />You're just asking about the standard java.util.ArrayList collection<br />class. In that case, these are being returned as<br />flex.messaging.io.ArrayCollection instances by default, the equivalent<br />for that class on the client is mx.collections.ArrayCollection. So....<br />you would need to ensure mx.collections.ArrayCollection is linked into<br />your SWF in the manner described earlier.<br /> <br />Or.... you can change the BlazeDS endpoint serialization setting<br />"legacy-collection" to true to get it to return ActionScript Arrays for<br />Java Collections. See:<br /> <br />http://livedocs.adobe.com/blazeds/1/blazeds_devguide/help.html?content=s<br />erialize_data_3.html<br /> <br />i.e.<br /> <br />        <channel-definition id="my-amf"<br />class="mx.messaging.channels.AMFChannel"><br />            <endpoint<br />url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf<br />" class="flex.messaging.endpoints.AMFEndpoint"/><br />            <properties><br />                <polling-enabled>false</polling-enabled><br />                <serialization><br />                    <legacy-collection>true</legacy-collection><br />                </serialization><br />            </properties><br />        </channel-definition><br /><br /><br /><br /><br />------------------------------------------------------------------------<br />--------<br />From: Russell C Taylor [mailto:member@adobeforums.com] <br />Sent: Monday, June 23, 2008 11:38 AM<br />To: blazeds-gettingstarted@adobeforums.com<br />Subject: Re: BlazeDS FlashDevelop RPC ArrayList<br /><br /><br />A new message was posted by Russell C Taylor in <br /><br />Configuration and Getting Started Discussion --<br />  BlazeDS FlashDevelop RPC ArrayList<br /><br />Here's the method that creates the ArrayList I wish to parse to the<br />client. <br /><br />/** <br />* Search results method parses the HashMap <br />* and returns a result list collection <br />* <br />* @param ids HashMap<String, int[]> <br />* <br />* @return List collection of results <br />*/ <br />public static ArrayList<IdeaRO> getSphinxArray(HashMap<String, int[]><br />ids) throws SQLException{ <br />ArrayList<IdeaRO> list = new ArrayList<IdeaRO>(); <br />Connection c = null; <br /><br />try{ <br />c = ConnectionHelper.getConnection(); <br />Statement s = c.createStatement(); <br />for (Iterator<Map.Entry<String, int[]>> entry=ids.entrySet().iterator();<br />entry.hasNext();){ <br />Map.Entry<String, int[]> key = (Map.Entry<String, int[]>)entry.next(); <br />for(int id:key.getValue()){ <br />ResultSet rs = s.executeQuery("SELECT `tbi_db_test`.`post`.`title`,<br />`tbi_db_test`.`link`.`url`, `tbi_db_test`.`levelindicator`.`level`,<br />`tbi_db_test`.`scorerelation`.`score_plus`,<br />`tbi_db_test`.`scorerelation`.`score_minus` FROM `tbi_db_test`.`post`<br />JOIN tbi_db_test.link ON<br />tbi_db_test.post.post_id=tbi_db_test.link.post_id_fk JOIN<br />tbi_db_test.levelindicator ON<br />tbi_db_test.post.post_id=tbi_db_test.levelindicator.post_id_fk JOIN<br />tbi_db_test.scorerelation ON<br />tbi_db_test.post.post_id=tbi_db_test.scorerelation.post_id_fk WHERE<br />tbi_db_test.post.post_id="+(int)id); <br />while(rs.next()){ <br />IdeaRO result = new IdeaRO(); <br />result.setId((int)id); <br />result.setTitle(rs.getString("title")); <br />result.setImageURL(rs.getString("url")); <br />result.setLevel(rs.getInt("level")); <br />result.setPlusScore(rs.getInt("score_plus")); <br />result.setMinusScore(rs.getInt("score_minus")); <br />list.add(result); <br />} <br />} <br />} <br />}finally{ <br />c.close(); <br />} <br /><br />return list; <br />}; <br /><br /><br />------------------------------------------------------------------------<br />--------<br />View/reply at BlazeDS FlashDevelop RPC ArrayList<br />Replies by email are OK.<br />Use the unsubscribe form to cancel your email subscription.
                        • 9. Re: BlazeDS FlashDevelop RPC ArrayList
                          Newcomer
                          I had already set the legacy to true in the service-config.xml file.<br /><br />Does it make a difference if I am not compiling the service-config.xml with the SWF (only deployed in web-inf/flex on the server)?<br /><br />And I originally had ArrayCollections rather than ArrayList after reading the article before my first post.  So it's back to square one, because I still have the same error.<br /><br />ArgumentError: Error #2004: One of the parameters is invalid.<br /><br />Also, after I hit <continue> the result set then returns null.<br /><br />This post highlights my problem;<br /><br />http://iamjosh.wordpress.com/2007/12/12/serialization-of-custom-collections-for-flex-da ta-services/
                          • 10. Re: BlazeDS FlashDevelop RPC ArrayList
                            Newcomer
                            Just found this in BlazeDS log file;<br /><br />flex.messaging.config.ConfigurationException: Unexpected child element 'legacy-collection' found in 'channel-definition' from file: services-config.xml.<br /><br />here's my service-config;<br /><br /><?xml version="1.0" encoding="UTF-8"?><br /><services-config><br /><br />    <services><br />        <service-include file-path="remoting-config.xml" /><br />        <service-include file-path="proxy-config.xml" /><br />        <service-include file-path="messaging-config.xml" />        <br />    </services><br /><br />    <security><br />        <login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/><br />        <!-- Uncomment the correct app server<br />        <login-command class="flex.messaging.security.TomcatLoginCommand" server="JBoss"><br />          <login-command class="flex.messaging.security.JRunLoginCommand" server="JRun"/>        <br />        <login-command class="flex.messaging.security.WeblogicLoginCommand" server="Weblogic"/><br />        <login-command class="flex.messaging.security.WebSphereLoginCommand" server="WebSphere"/><br />        --><br /><br />        <!-- <br />        <security-constraint id="basic-read-access"><br />            <auth-method>Basic</auth-method><br />            <roles><br />                <role>guests</role><br />                <role>accountants</role><br />                <role>employees</role><br />                <role>managers</role><br />            </roles><br />        </security-constraint><br />         --><br />    </security><br /><br />    <channels><br /><br />        <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel"><br />            <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>     <br />          <properties><br />                <polling-enabled>false</polling-enabled>                 <br />               <serialization>                     <br />                    <legacy-collection>true</legacy-collection>                <br />               </serialization><br />            </properties>     <br />        </channel-definition><br /><br />        <channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel"><br />            <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/><br />            <properties><br />                <polling-enabled>true</polling-enabled><br />                <polling-interval-seconds>4</polling-interval-seconds><br />          <serialization>                     <br />               <legacy-collection>true</legacy-collection>                <br />          </serialization><br />            </properties><br />        </channel-definition><br /><br />    </channels><br /><br />    <logging><br />        <target class="flex.messaging.log.ConsoleTarget" level="Error"><br />            <properties><br />                <prefix>[BlazeDS] </prefix><br />                <includeDate>true</includeDate><br />                <includeTime>true</includeTime><br />                <includeLevel>true</includeLevel><br />                <includeCategory>true</includeCategory><br />            </properties><br />            <filters><br />                <pattern>Endpoint.*</pattern><br />                <pattern>Service.*</pattern><br />                <pattern>Configuration</pattern><br />            </filters><br />        </target><br />    </logging><br /><br />    <system><br />        <redeploy><br />            <enabled>true</enabled><br /><br />            <watch-interval>20</watch-interval><br />            <watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file><br /><br />            <watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file><br /><br />            <touch-file>{context.root}/WEB-INF/web.xml</touch-file><br />   <br />        </redeploy><br />    </system><br /><br /></services-config>
                            • 11. Re: BlazeDS FlashDevelop RPC ArrayList
                              Newcomer
                              Ignore my last post. The error message was old.
                              I'm also using the latest BlazeDS BETA 3.0.2?
                              • 12. Re: BlazeDS FlashDevelop RPC ArrayList
                                Newcomer
                                I switched logging to All and the log output from BlazeDS is a little strange.
                                Two ArrayList are output for each transaction. The first is correct for example;
                                [69] = tbi.DAO.IdeaRO
                                id = 260
                                title = MSDN Webcast: Unified Communications 101
                                minusScore = 1
                                level = 1
                                plusScore = 1
                                imageURL = test
                                This maps correctly to IdeaRO, but the second has no (int);
                                [69] = (Externalizable Object #70 'tbi.DAO.IdeaRO')
                                "MSDN Webcast: Unified Communications 101"
                                "test"
                                Where have the integers gone?
                                Thanks for your patience.
                                • 13. Re: BlazeDS FlashDevelop RPC ArrayList
                                  Newcomer
                                  I've removed the Externalizable implementation and I have a mutli-dimensional array returned. Wahoo!
                                  • 14. Re: BlazeDS FlashDevelop RPC ArrayList
                                    It seems non-AMF 3 focused write methods don't trace debug output (they
                                    just delegate to the standard Java implementation from
                                    java.io.DataOutput).
                                    http://opensource.adobe.com/svn/opensource/blazeds/branches/3.0.x/module
                                    s/core/src/java/flex/messaging/io/amf/AbstractAmfOutput.java
                                    • 15. Re: BlazeDS FlashDevelop RPC ArrayList
                                      Newcomer
                                      Thanks for that link Peter,
                                      I was using writeFloat to externalize integers in the DataOuput, I think I found this an a dev guide example. The link suggests I should have been using writeInt?
                                      My quest to serialize custom objects continues, but at least the app is working (if not efficiently). The biggest triumph was successfully using the low-level NetConnection framework with pure actionscript and the Flex SDK to remote with BlazeDS. Creating a blazing fast app with completely open-source products. Keep up the good work!
