0 Replies Latest reply on Sep 30, 2008 4:37 PM by deepa subramaniam (adobe)
    [svn] 3431: Changing the default value of blendMode in Flex Graphics from ' normal' to 'layer' as part of the ARB proposal documented here:
    deepa subramaniam (adobe) Level 2
      Revision: 3431
      Author: dsubrama@adobe.com
      Date: 2008-09-30 17:37:13 -0700 (Tue, 30 Sep 2008)
      Log Message:
      Changing the default value of blendMode in Flex Graphics from 'normal' to 'layer' as part of the ARB proposal documented here:
      https://zerowing.corp.adobe.com/display/flex/Default+Blend+Modes
      Instead of always setting blendMode to 'layer' we only set it when a rendering difference is detected, basically the alpha of a parent Group is > 0 and < 1, otherwise blendMode is normal or whatever the user has explicitly set. However, when you get blendMode, you always get 'layer' or whatever the user has explicitly set.
      Checkintests: Pass
      QA: Yes - those 14 tests need new bitmap compares though, and any tests around getting the blendMode default value need to be updated to check for 'layer'.
      Doc: Needed
      Review: Glenn
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/GraphicElement .as
