0 Replies Latest reply on Oct 2, 2008 8:13 PM by Ely Greenfield
    [svn] 3466: Refactored TransformOffset to reduce code and confusion.
    Ely Greenfield Level 1
      Revision: 3466
      Author: egreenfi@adobe.com
      Date: 2008-10-02 21:13:46 -0700 (Thu, 02 Oct 2008)
      Log Message:
      UIComponent and GraphicElement now aggregate an AdvancedLayoutFeatures object, which is responsible for computing the
      actual transform based on the layout properties and a CompoundTransform object passed in as a set of offset values.
      Re-enabled updateComplete events when component transform is modified, for mustella tests.
      Review: Glenn, Evtim.
      Modified Paths:
      flex/sdk/trunk/frameworks/halo-manifest.xml
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Path.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/GraphicElement .as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/tools/dependencychecker/frameworkSwcExceptionsList.txt
      Added Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/CompoundTransform.as
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/TransformOffset.as
