0 Replies Latest reply on Oct 3, 2008 12:34 PM by Glenn Ruehle
    [svn] 3478: Remove prototype Gumbo Panel component.
    Glenn Ruehle Adobe Employee
      Revision: 3478
      Author: gruehle@adobe.com
      Date: 2008-10-03 13:34:49 -0700 (Fri, 03 Oct 2008)
      Log Message:
      Remove prototype Gumbo Panel component. This will be reinstated in a future build.
      Remove the "selected" property from SkinnableComponent. "selected" is only on ToggleButton (including CheckBox/RadioButton), and ItemRenderer.
      Bugs: SDK-16349 SkinnableComponent shouldn't define "selected"
      SDK-16799 Gumbo Panel needs to be removed from build
      QA: Tests using Panel need to be updated
      Reviewer: Chet
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16349
      http://bugs.adobe.com/jira/browse/SDK-16799
      Modified Paths:
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/defaults.css
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/Flex4Classes.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ItemRenderer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ToggleButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/MXMLComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/SkinnableComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/MoveInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/ResizeInstance.as
      flex/sdk/trunk/frameworks/tests/flex4/flex4test.mxml
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Panel.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ComplexPanelSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/PanelSkin.mxml
