0 Replies Latest reply on Oct 3, 2008 4:27 PM by (Ryan_Frishberg)
    [svn] 3483: Few different changes, most to Group and DataGroup:
    Level 1
      Revision: 3483
      Author: rfrishbe@adobe.com
      Date: 2008-10-03 17:27:35 -0700 (Fri, 03 Oct 2008)
      Log Message:
      1. GroupBase - added simple class ASDoc so it'll hopefully be included in the nightly ASDoc builds
      2. Group - Removed support for ILists from Group.
      3. ToggleButton - Moved around a method from skinLoaded to the constructor since it was just adding an event listener to the object and not the skin instance
      4. DataGroup - Cleaned up a lot of the logic when a collectionChange event happens so that we don't just remove everything and add everything all the time. This also fixes a bug. Will work with QA to make sure this gets tested for all scenarios.
      QE: Yes
      Doc: Yes
      Bugs: SDK-17179
      Reviewer: Evtim, Glenn
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17179
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ToggleButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/DataGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/GroupBase.as
