0 Replies Latest reply on Oct 6, 2008 10:44 PM by Ely Greenfield
    [svn] 3504: New flag to allow a component to maintain a centered perspective transform , plus other minor transform cleanup.
    Ely Greenfield Level 1
      Revision: 3504
      Author: egreenfi@adobe.com
      Date: 2008-10-06 23:44:07 -0700 (Mon, 06 Oct 2008)
      Log Message:
      New flag to allow a component to maintain a centered perspective transform, plus other minor transform cleanup.
      setting the layout matrix or matrix3D now resets transform X/Y/Z to 0.
      setting the component's x/y/z or calling move or setActualSize no longer blows away non-standard transforms (i.e., shear).
      UIComponents can now maintain a centered perspective transform.
      Modified Paths:
      flex/sdk/trunk/frameworks/gumbo-manifest.xml
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/CompoundTransform.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/Transform.as
      Added Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Animate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Rotate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/Animate3DInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/Rotate3DInstance. as
