0 Replies Latest reply on Oct 7, 2008 10:19 AM by (Jim_Murphy)
    [svn] 3509: Rename of flex -> mx.
    Level 1
      Revision: 3509
      Author: jimurphy@adobe.com
      Date: 2008-10-07 11:19:17 -0700 (Tue, 07 Oct 2008)
      Log Message:
      For compatibility reasons it was decided that the new functionality remain integrated with the old framework, although we will continue to build two separate SWCs, one with primarily existing framework classes, and one with new Flex 4 classes. This change removes duplicate names from the Flex 4 framework to avoid class name overlapping with the old framework code. The naming overlap consists of two major areas: New Components, and New Effects
      Modified Paths:
      flex/sdk/trunk/frameworks/fxg-manifest.xml
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/defaults.css
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/Flex4Classes.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexEvent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
      flex/sdk/trunk/frameworks/tests/flex4/flex4test.mxml
      flex/sdk/trunk/frameworks/tests/fxgCompile/fxgCompileTest.mxml
      flex/sdk/trunk/frameworks/tests/graphics/GraphicTags_checkin.mxml
      flex/sdk/trunk/frameworks/tests/graphics/GraphicTags_checkintests.mxml
      flex/sdk/trunk/frameworks/tests/layout/layout.mxml
      flex/sdk/trunk/frameworks/tests/layout/layout_tester.mxml
      flex/sdk/trunk/frameworks/tests/states/statefulAttributes.mxml
      flex/sdk/trunk/frameworks/tests/states/statefulNodes.mxml
      flex/sdk/trunk/frameworks/tools/FXGViewer/src/FXGViewer.mxml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/mustella/mustella.swc
      Added Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/ContainerBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/DataGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxApplication.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxCheckBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxDataComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxHScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxHSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxItemsComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxList.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxNumericStepper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxRadioButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxScroller.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxSpinner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxTextArea.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxTextInput.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxToggleButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxVSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/HGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/ItemRenderer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/MXMLComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/ResizeMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Skin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/TextBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/VGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxRange.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxSelector.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxTrackBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/IDeferredContentOwner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/IViewport.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/core/Version.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/AddAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/Animate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/Animation.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/CallAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimateColor.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimateFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxFade.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxMove.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxResize.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxRotate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/PropertyValuesHolder.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/RemoveAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/Rotate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/SetAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/Wait.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/easing/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/easing/Constant.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/easing/EaseInOut.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/easing/IEaser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/easing/Linear.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/easing/Power.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/easing/Sine.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/AddActionInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/Animate3DInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/CallActionInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateColorInsta nce.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateFilterInst ance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxFadeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxMoveInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxResizeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxRotateInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/RemoveActionInstanc e.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/Rotate3DInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/SetActionInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/WaitInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/ArrayInterpolator.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/ColorInterpolator.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/IInterpolator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/NumberArrayInterpol ator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/interpolation/NumberInterpolator. as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/AnimationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/ItemExistenceChangedEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/TextOperationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/BevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/BlurFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ColorMatrixFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ConvolutionFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/DisplacementMapFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/DropShadowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientBevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/GradientGlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/filters/ShaderFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/geom/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/BitmapGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/BitmapResizeMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/CloseSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/CubicBezierSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Ellipse.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/FilledElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Graphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/IGraphicElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/IGraphicElementHost.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Line.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/LineSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/MaskType.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/MoveSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Parser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Path.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/PathSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/QuadraticBezierSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Rect.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/StrokedElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/TextBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/TextGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElement.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElementHo stImpl.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/TextBlockCompose r.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/TextFlowComposer .as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/TextGraphicEleme nt.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/BasicLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/HorizontalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/ILayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/ILayoutItem.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutItemFDO.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutItemFactory.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutItemHelper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutItemUIC.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/VerticalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxApplicationSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxCheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxDataComponentSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxDefaultComplexItemRenderer. mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxDefaultItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxItemsComponentSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxListSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxNumericStepperSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxRadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarDownButtonSkin.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarLeftButtonSkin.mxm l
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarRightButtonSkin.mx ml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollBarUpButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxScrollerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSelectorSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerDecrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerIncrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxTextAreaSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxTextInputSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxToggleButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/states/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/states/AddItems.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/AdvancedCharacterFormatTe xtStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/AdvancedContainerFormatTe xtStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/AdvancedParagraphFormatTe xtStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/BasicCharacterFormatTextS tyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/BasicContainerFormatTextS tyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/styles/metadata/BasicParagraphFormatTextS tyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/Flags32.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/MatrixUtil.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/TextUtil.as
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Button.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/CheckBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ContainerBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/DataComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/HGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/HScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/HSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ItemRenderer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ItemsComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/List.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/NumericStepper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/RadioButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Range.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Scroller.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Selector.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Slider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Spinner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextArea.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextInput.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ToggleButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TrackBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/VGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/VScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/VSlider.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Application.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/DataGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Flags32.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/IDeferredContentOwner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/MXMLComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/ResizeMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Skin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/SkinnableComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Version.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/AddAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Animate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Animate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/AnimateFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Animation.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/CallFunctionAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Fade.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Move.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/PropertyValuesHolder.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/RemoveAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Resize.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Rotate.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Rotate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/SetAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Tint.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Wait.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/easing/Constant.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/easing/EaseInOut.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/easing/IEaser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/easing/Linear.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/easing/Power.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/easing/Sine.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/AddActionInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/Animate3DInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/AnimateFilterInst ance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/AnimateInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/CallFunctionActio nInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/FadeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/MoveInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/RemoveActionInsta nce.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/ResizeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/Rotate3DInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/RotateInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/SetActionInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/TintInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/WaitInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/interpolation/ArrayInterpolator .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/interpolation/ColorInterpolator .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/interpolation/IInterpolator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/interpolation/NumberArrayInterp olator.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/interpolation/NumberInterpolato r.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/AnimationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/FlexEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/ItemExistenceChangedEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/TextOperationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/BevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/BlurFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/ColorMatrixFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/ConvolutionFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/DisplacementMapFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/DropShadowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/GlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/GradientBevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/GradientFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/GradientGlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/ShaderFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/BitmapGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/BitmapResizeMode.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/CloseSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/CubicBezierSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Ellipse.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/FilledElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Graphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/IGraphicElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/IGraphicElementHost.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Line.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/LineSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/MaskType.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/MoveSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Parser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Path.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/PathSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/QuadraticBezierSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Rect.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/StrokedElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/TextBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/TextGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/TransformUtil.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/GraphicElement .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/GraphicElement HostImpl.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextBlockCompo ser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextFlowCompos er.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextGraphicEle ment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/intf/ILayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/intf/ILayoutItem.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/intf/IViewport.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/BasicLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/HorizontalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutItemFDO.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutItemFactory.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutItemHelper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutItemUIC.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/VerticalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ApplicationSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/CheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/DataComponentSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/DefaultComplexItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/DefaultItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ItemsComponentSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ListSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/NumericStepperSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/RadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollBarDownButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollBarLeftButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollBarRightButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollBarUpButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/SelectorSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/SpinnerDecrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/SpinnerIncrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/SpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/TextAreaSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/TextInputSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ToggleButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/states/AddItems.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/styles/metadata/AdvancedCharacterFormat TextStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/styles/metadata/AdvancedContainerFormat TextStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/styles/metadata/AdvancedParagraphFormat TextStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/styles/metadata/BasicCharacterFormatTex tStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/styles/metadata/BasicContainerFormatTex tStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/styles/metadata/BasicParagraphFormatTex tStyles.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/utils/TextUtil.as
