0 Replies Latest reply on Oct 9, 2008 12:21 PM by (Paul_Reilly)
    [svn] 3548: Fixed conditional compilation with direct AST generation.
    Level 1
      Revision: 3548
      Author: preilly@adobe.com
      Date: 2008-10-09 13:21:22 -0700 (Thu, 09 Oct 2008)
      Log Message:
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-16376
      API Change: NO
      Reviewer: pfarland, tierney (hopefully in progress)
      Code-level description of changes:
      modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      Modified constructor to populate configNamespaces and pass the
      result of parseConfigVars() into generateProgram().
      Modified all AbstractSyntaxTreeUtil.parse() calls to pass in
      configNamespaces.
      modules/compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      Added configNamespaces variable.
      configNamespaces.
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/EventInitializer.java
      Modified generateDefinitions() by adding configNamespaces param
      and passing it into AbstractSyntaxTreeUtil.parse().
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/Initializer.java
      Modified generateDefinitions() by adding configNamespaces param.
      modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
      modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
      Modified generateWatcherSetupUtilAST() to populate
      configNamespaces and pass it down to all the places where we call
      modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Modified generateProgram() to take configVars param instead of
      calling parseConfigVars() directly.
      Modified parse() to take a configNamespaces param.
      Modified parseConfigVars() to use Parser.parseConfigValues() now
      that it's public.
      modules/asc/src/java/macromedia/asc/parser/Parser.java
      Made parseConfigValues() public.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16376
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/EventInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/Initializer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
