0 Replies Latest reply on Oct 9, 2008 2:07 PM by (Ryan_Frishberg)
    [svn] 3552: This patch contains multiple changes, mostly renames, outlined below:
    Level 1
      Revision: 3552
      Author: rfrishbe@adobe.com
      Date: 2008-10-09 15:07:55 -0700 (Thu, 09 Oct 2008)
      Log Message:
      1.Rename properties in FxComponent: skinObject -> skin, skinZZ -> skinClass.
      2.Rename property in Skin: data -> fxComponent (this also means Skin doesn?\226?\128?\153t implement IDataRenderer anymore)
      3.Renames in DataGroup: Mostly around "skin" to "renderer" to get terminology correct
      4.Random other cleanups: For instance changing typing of "*" to "Object" in ItemsComponent and DataGroup or removing some un-used imports in Group and GroupBase.
      5.Lots of cleanup in flex4tests to deal with renaming of classes and renaming of properties
      6.Gumbo-manifest.mxml - typo...some files listed as mx.componentss.* instead of mx.components.*. This file is going away as all components are moved into the 2009 namespace, but we'll fix this for now.
      7.Defaults.css ?\226?\128?\147 FxDataComponent should be FxDataContainer.
      8.SystemManger fix: this was in the previous SystemManager but got overwritten by a bad merge. Jim?\226?\128?\153s aware of the issue, and I?\226?\128?\153m checking in the fix for it.
      QE: Yes - Joann and Steve have pre-emptively made the changes
      Doc: Yes
      Bugs: SDK-17056, SDK-17174
      Reviewer: Chet, Evtim
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17056
      http://bugs.adobe.com/jira/browse/SDK-17174
      Modified Paths:
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/AddItemsTest.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/EffectsProperties.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/NewEffects.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/RemoveItemsTest.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/ScrollbarFrenzy.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/components/AnimationPropertiesForm. mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/components/CircularScrollBar.as
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/flex4test.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/skins/CircularScrollBarSkin.mxml
      flex/sdk/trunk/development/eclipse/flex/flex4test/src/skins/MyVScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/defaults.css
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/DataGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxList.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxScroller.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Skin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxApplicationSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxHSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxNumericStepperSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxSpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/skins/spark/FxVSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
