0 Replies Latest reply on Oct 10, 2008 11:34 AM by Peter Farland
    [svn] 3573: Removing the halo and gumbo library namespaces and merging all applicable tags into MXML 2009 .
    Peter Farland Level 3
      Revision: 3573<br />Author:   pfarland@adobe.com<br />Date:     2008-10-10 12:34:21 -0700 (Fri, 10 Oct 2008)<br /><br />Log Message:<br />-----------<br />Removing the halo and gumbo library namespaces and merging all applicable tags into MXML 2009.<br /><br />Note that in MXML 2009, the filters tags <BevelFilter>, <BlurFilter>, <ColorMatrixFilter>, <ConvolutionFilter>, <DisplacementMapFilter>, <DropShadowFilter>, <DropShadowFilter>, <GlowFilter>, <GradientBevelFilter> and <GradientGlowFilter> map to their new mx.filters.* implementation (which include FXG support). To use the MXML 2006 flash.filters.* based tags in MXML 2009, they would need to be qualified in a custom flash.filters.* package namespace in order to be used as tags.<br /><br />QA: Yes, please replace all usages of "library:adobe/flex/gumbo" and "library:adobe/flex/halo" with "http://ns.adobe.com/mxml/2009".<br />Docs: Yes, if we have documented the library specific namespaces, please replace them with the new MXML 2009 namespace. Our MXML 2009 spec will be updated to reflect these changes too.<br />Bugs: SDK-17051<br />Checkintests: Pass<br />Reviewer: Deepa<br /><br />Ticket Links:<br />------------<br />    http://bugs.adobe.com/jira/browse/SDK-17051<br /><br />Modified Paths:<br />--------------<br />    flex/sdk/trunk/development/eclipse/flex/flex4/.actionScriptProperties<br />    flex/sdk/trunk/development/eclipse/flex/flex4/.flexLibProperties<br />    flex/sdk/trunk/development/eclipse/flex/flex4/.project<br />    flex/sdk/trunk/development/eclipse/flex/flex4test/src/AddItemsTest.mxml<br />    flex/sdk/trunk/development/eclipse/flex/flex4test/src/EffectsProperties.mxml<br />    flex/sdk/trunk/development/eclipse/flex/flex4test/src/NewEffects.mxml<br />    flex/sdk/trunk/development/eclipse/flex/flex4test/src/RemoveItemsTest.mxml<br />    flex/sdk/trunk/development/eclipse/flex/flex4test/src/ScrollbarFrenzy.mxml<br />    flex/sdk/trunk/development/eclipse/flex/flex4test/src/components/AnimationPropertiesForm. mxml<br />    flex/sdk/trunk/development/eclipse/flex/flex4test/src/flex4test.mxml<br />    flex/sdk/trunk/frameworks/air-config.xml<br />    flex/sdk/trunk/frameworks/flex-config.xml<br />    flex/sdk/trunk/frameworks/mxml-2009-manifest.xml<br />    flex/sdk/trunk/frameworks/projects/flex4/build.xml<br />    flex/sdk/trunk/frameworks/projects/flex4/manifest.xml<br />    flex/sdk/trunk/frameworks/tests/flex4/flex4test.mxml<br />    flex/sdk/trunk/frameworks/tests/graphics/GraphicTags_checkin.mxml<br />    flex/sdk/trunk/frameworks/tests/graphics/comps/EllipseBasic2.mxml<br />    flex/sdk/trunk/frameworks/tests/graphics/comps/RectBasic3.mxml<br />    flex/sdk/trunk/frameworks/tests/graphics/comps/TextGraphicBasic1.mxml<br />    flex/sdk/trunk/frameworks/tests/layout/layout.mxml<br />    flex/sdk/trunk/frameworks/tests/states/statefulAttributes.mxml<br />    flex/sdk/trunk/frameworks/tests/states/statefulNodes.mxml<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MXMLNamespaces.java<br />    flex/sdk/trunk/samples/explorer/explorer.mxml<br /><br />Removed Paths:<br />-------------<br />    flex/sdk/trunk/frameworks/gumbo-manifest.xml<br />    flex/sdk/trunk/frameworks/halo-manifest.xml
