0 Replies Latest reply on Oct 10, 2008 4:13 PM by Ely Greenfield
    [svn] 3582: FxRotate3D effect now no longer uses the component' s transform point to rotate, but rather adjusts x/ y to simulate rotation around its transform center.
    Ely Greenfield Level 1
      Revision: 3582
      Author: egreenfi@adobe.com
      Date: 2008-10-10 17:13:59 -0700 (Fri, 10 Oct 2008)
      Log Message:
      FxRotate3D effect now no longer uses the component's transform point to rotate, but rather adjusts x/y to simulate rotation around its transform center. It does so using a new transformAround() method added to ITransformable (including implemetnations by UICompoennt, GraphicElement, and CompoundTransform)
      REview: Chet
      QA: shouldn't affect any existing test cases
      Checkintests: passed
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimate3DInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimateInstance.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxRotate3DInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElement.a s
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/CompoundTransform.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/ITransformable.as
