0 Replies Latest reply on Oct 13, 2008 8:32 PM by Gaurav J
    [svn] 3616: Reverting the change for dita xml in swc files.
    Gaurav J Adobe Employee
      Revision: 3616
      Author: gauravj@adobe.com
      Date: 2008-10-13 21:32:54 -0700 (Mon, 13 Oct 2008)
      Log Message:
      Previous change significantly slowed down the compiler for larger multi library/modules apps..
      QA: No
      Doc: No
      Tests: checkintests
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/airframework/build.xml
      flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
      flex/sdk/trunk/frameworks/projects/flex/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/framework/build.xml
      flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
      flex/sdk/trunk/frameworks/projects/rpc/build.xml
      flex/sdk/trunk/frameworks/projects/utilities/build.xml
