0 Replies Latest reply on Oct 14, 2008 8:37 AM by Gaurav J
    [svn] 3625: Retry the change to update the swcs with dita based asdoc xml files.
    Gaurav J Adobe Employee
      Revision: 3625
      Author: gauravj@adobe.com
      Date: 2008-10-14 09:37:56 -0700 (Tue, 14 Oct 2008)
      Log Message:
      But this time with lazy read set to true.
      QA: No
      Doc: No
      Tests: checkintests
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/airframework/build.xml
      flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
      flex/sdk/trunk/frameworks/projects/flex/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/framework/build.xml
      flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
      flex/sdk/trunk/frameworks/projects/rpc/build.xml
      flex/sdk/trunk/frameworks/projects/utilities/build.xml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcCache.java
