0 Replies Latest reply on Oct 14, 2008 3:49 PM by Gaurav J
    [svn] 3638: Changing the build order of swc file update with dita xml files .
    Gaurav J Adobe Employee
      Revision: 3638
      Author: gauravj@adobe.com
      Date: 2008-10-14 16:49:56 -0700 (Tue, 14 Oct 2008)
      Log Message:
      Changing the build order of swc file update with dita xml files.
      By default this would now happen during the checkintests target - so "ant clean main" shouldn't get affected.
      To opt out use -Dno.doc=true
      QA: No
      Doc: No
      Tests: checkintests
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/projects/airframework/build.xml
      flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
      flex/sdk/trunk/frameworks/projects/flex/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/framework/build.xml
      flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
      flex/sdk/trunk/frameworks/projects/rpc/build.xml
      flex/sdk/trunk/frameworks/projects/utilities/build.xml
