0 Replies Latest reply on Oct 14, 2008 4:52 PM by Peter Farland
    [svn] 3640: Changing to a stable sort algorithm so that equivalent selector order is preserved .
    Peter Farland Level 3
      Revision: 3640
      Author: pfarland@adobe.com
      Date: 2008-10-14 17:52:58 -0700 (Tue, 14 Oct 2008)
      Log Message:
      Changing to a stable sort algorithm so that equivalent selector order is preserved. Also fixing a cut and paste error for CSS style modules in the StyleModule.vm velocity template to match what Flex 3 behavior did but accommodating multiple style declarations per "StyleDef" instance in the compiler.
      QE: Yes
      Doc: No
      Checkintests: Pass
      Reviewer: Ryan
      SDK-17329 - [Advanced CSS] Type selectors no longer work when using runtime CSS
      SDK-17330 - [Advanced CSS] When you apply a messageName style to an Alert, the Alert loses its rounded corners.
      SDK-17325 - [Advanced CSS] When a styleName is applied to a TitleWindow, it is applied to the entire container rather than just the content area.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17329
      http://bugs.adobe.com/jira/browse/SDK-17330
      http://bugs.adobe.com/jira/browse/SDK-17325
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.vm
