0 Replies Latest reply on Oct 14, 2008 7:19 PM by Ely Greenfield
    [svn] 3645: removed ability to set transform offsets as a matrix
    Ely Greenfield Level 1
      Revision: 3645
      Author: egreenfi@adobe.com
      Date: 2008-10-14 20:19:36 -0700 (Tue, 14 Oct 2008)
      Log Message:
      TransformOffsets are applied as r/s/t deltas, not as a matrix, so it doesn't make sense to allow developers to set matrix values directly.
      Also renamed matrix/matrix3D on UIC and GraphicElement to layoutMatrix/layoutMatrix3D, as these are more appropriate names, and removing them from transformOffsets gives us more freedom in their naming.
      Reviewer: Glenn
      checkintests: pass
      QA: none
      Modified Paths:
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAnimate3DInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxRotate3DInstance. as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElement.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutItemUIC.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualItem.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/CompoundTransform.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/ITransformable.as
      flex/sdk/trunk/tools/dependencychecker/frameworkSwcExceptionsList.txt
      Added Paths:
      flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/TransformOffsets.as
