0 Replies Latest reply on Oct 15, 2008 3:54 PM by (Corey_Lucier)
    [svn] 3672: Removing the commonly used getUnqualifiedClassName out of the less commonly used utility class to reduce SWF size for the general case .
    Level 1
      Revision: 3672
      Author: clucier@adobe.com
      Date: 2008-10-15 16:54:51 -0700 (Wed, 15 Oct 2008)
      Log Message:
      Removing the commonly used getUnqualifiedClassName out of the less commonly used utility class to reduce SWF size for the general case.
      Reviewer: Gordon
      QE: No
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/TextGraphicEleme nt.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectInstance.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/NameUtil.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/ObjectUtil.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/OrderedObject.as
