0 Replies Latest reply on Oct 17, 2008 5:52 AM by Peter Farland
    [svn] 3704: First part of a fix related to bug SDK-17104 ( this broke when we moved to direct AST generation).
    Peter Farland Level 3
      Revision: 3704
      Author: pfarland@adobe.com
      Date: 2008-10-17 06:52:50 -0700 (Fri, 17 Oct 2008)
      Log Message:
      First part of a fix related to bug SDK-17104 (this broke when we moved to direct AST generation). I missed this feature in my initial advanced CSS check-in too. This change only addresses the velocity side of the fix. Direct AST gen is the other part which will have to be in a separate changelist.
      QA: Not yet (although with -keep true you could test this works)
      Doc: No
      Checkintests: Pass
      Reviewer: Darrell
      Bugs:
      Partial fix part for Advanced CSS work, related to
      SDK-17104 - Assigning an effect trigger in CSS no longer works in Flex 4
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17104
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleDeclaration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
