0 Replies Latest reply on Oct 17, 2008 9:46 AM by Glenn Ruehle
    [svn] 3710: Moved the wireframe skins into a "Wireframe" theme.
    Glenn Ruehle Adobe Employee
      Revision: 3710
      Author: gruehle@adobe.com
      Date: 2008-10-17 10:46:28 -0700 (Fri, 17 Oct 2008)
      Log Message:
      Moved the wireframe skins into a "Wireframe" theme. A subsequent checkin is required to include the theme in the SDK builds.
      Spiffed up the wireframe skins a bit to make them look better.
      QA: Yes, please add tests that include the wireframe theme. This theme only applies to Gumbo components.
      Bugs: SDK-17342, SDK-15855
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17342
      http://bugs.adobe.com/jira/browse/SDK-15855
      Modified Paths:
      flex/sdk/trunk/frameworks/build.xml
      Added Paths:
      flex/sdk/trunk/frameworks/projects/wireframe/
      flex/sdk/trunk/frameworks/projects/wireframe/build.xml
      flex/sdk/trunk/frameworks/projects/wireframe/bundles.properties
      flex/sdk/trunk/frameworks/projects/wireframe/defaults.css
      flex/sdk/trunk/frameworks/projects/wireframe/src/
      flex/sdk/trunk/frameworks/projects/wireframe/src/WireframeClasses.as
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxCheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxDefaultComplexItemRenderer.m xml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxDefaultItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxHSliderTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxListSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxNumericStepperSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxRadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxScrollBarDownButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxScrollBarLeftButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxScrollBarRightButtonSkin.mxm l
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxScrollBarUpButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxSpinnerDecrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxSpinnerIncrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxSpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxTextAreaSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxTextInputSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxToggleButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVSliderSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVSliderThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/wireframe/src/wireframe/FxVSliderTrackSkin.mxml
      Property Changed:
      flex/sdk/trunk/frameworks/themes/
