0 Replies Latest reply on Oct 21, 2008 11:55 AM by (GordonSmith)
    [svn] 3789: Integrated Build 192 of what used to be called TCAL (and, before that, Vellum).
      Revision: 3789
      Author: gosmith@adobe.com
      Date: 2008-10-21 12:55:26 -0700 (Tue, 21 Oct 2008)
      Log Message:
      The Text Component ActionScript Library (TCAL) has been renamed to the Text Layout Framework. Its classes are now in the package flashx.textLayout rather than in flashx.tcal, and they are packaged into SWCs named textLayout_xxx.swc rather than tcal_xxx.swc. The XML namespace for importable markup is now "http://ns.adobe.com/textLayout/2008" rather than "http://ns.adobe.com/tcal/2008".
      QE Notes: Please update package names (and XML namespaces, if necessary) in all test files.
      Doc Notes: Please eliminate all references to "Text Component ActionScript Library" or "TCAL" and use "Text Layout Framework" instead.
      Bugs: -
      Reviewer: -
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/fxg-manifest.xml
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxTextInput.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/FxTextBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/events/TextOperationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/Parser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/TextGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/TextFlowComposer .as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/utils/TextUtil.as
      flex/sdk/trunk/frameworks/projects/wireframe/build.xml
      Added Paths:
      flex/sdk/trunk/frameworks/libs/textLayout_conversion.swc
      flex/sdk/trunk/frameworks/libs/textLayout_core.swc
      flex/sdk/trunk/frameworks/libs/textLayout_edit.swc
      Removed Paths:
      flex/sdk/trunk/frameworks/libs/tcal_conversion.swc
      flex/sdk/trunk/frameworks/libs/tcal_core.swc
      flex/sdk/trunk/frameworks/libs/tcal_edit.swc
