Revision: 3820
Author: gauravj@adobe.com
Date: 2008-10-22 11:06:28 -0700 (Wed, 22 Oct 2008)
Log Message:
ASDoc Bug fixes.
Changing show versions to true by default.
Modifying projects-asdoc.xml to use the renamed tcal swcs.
Removing some unused code from ASDocExtension.java, ClassTable.java, and DocCommentTable.java
QE Notes: None
Doc Notes: None
Reviewer: Paul
Bugs: SDK-17687, SDK-17679, SDK-17357
tests: checkintests
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-17687
http://bugs.adobe.com/jira/browse/SDK-17679
http://bugs.adobe.com/jira/browse/SDK-17357
Modified Paths:
flex/sdk/trunk/asdoc/projects-asdoc.xml
flex/sdk/trunk/asdoc/templates/ASDoc_Config_Base.xml
flex/sdk/trunk/asdoc/templates/asdoc-util.xslt
flex/sdk/trunk/asdoc/templates/class-files.xslt
flex/sdk/trunk/asdoc/templates/fieldSummary.xslt
flex/sdk/trunk/asdoc/templates/methodSummary.xslt
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ASDocExtension.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ClassTable.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/DocCommentTable.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/TopLevelClassesGenerator.java
