0 Replies Latest reply on Oct 24, 2008 6:35 AM by (Paul_Reilly)
    [svn] 3868: Fixed player asserts caused by incorrect debug info coming from Flex's
    Level 1
      Revision: 3868
      Author: preilly@adobe.com
      Date: 2008-10-24 07:35:38 -0700 (Fri, 24 Oct 2008)
      Log Message:
      bytecode emitter.
      tests Passed: checkintests, fdbunit tests pass equally as well before
      and after this change.
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-16948
      API Change: NO
      Reviewer: Erik
      Code-level description of changes:
      modules/compiler/src/java/flex2/compiler/as3/BytecodeEmitter.java
      Modified DebugLine() to short circuit like DebugFile() if the
      source is not debuggable. Also only call super.DebugLine() if the
      newLine is greater than zero. The player doesn't like zero line
      numbers.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16948
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/BytecodeEmitter.java
