0 Replies Latest reply on Oct 24, 2008 3:33 PM by (Evtim_Georgiev)
    [svn] 3892: Add constraint properties and unify IVisualItem, UIComponent, GraphicElement, change percentSize to percentWidth, percentHeight in ILayoutItem.
    Level 1
      Revision: 3892
      Author: egeorgie@adobe.com
      Date: 2008-10-24 16:33:52 -0700 (Fri, 24 Oct 2008)
      Log Message:
      Add constraint properties and unify IVisualItem, UIComponent, GraphicElement, change percentSize to percentWidth, percentHeight in ILayoutItem. Remove IGraphicElementHost and GraphicElementHostImpl. Change GraphicElement constraint properties to take in Object instead of Number to enable advanced constraints later on.
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: Ryan
      tests: checkintests, Mustella (canvas, gumbo layout)
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/DataGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/FxAnimate3D.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxMoveInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/effects/effectClasses/FxResizeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/BitmapGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/IGraphicElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/StrokedElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElement.a s
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/BasicLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/HorizontalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/ILayoutItem.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutItemFDO.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutItemHelper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/LayoutItemUIC.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/layout/VerticalLayout.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualItem.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/tools/dependencychecker/frameworkSwcExceptionsList.txt
      Removed Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/IGraphicElementHost.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElementHo stImpl.as
