0 Replies Latest reply on Oct 28, 2008 5:23 AM by Gaurav J
    [svn] 3921: Fix for - @inheritDoc tag not working for get/ set overrides when you only override the setter of a base class
    Gaurav J Adobe Employee
      Revision: 3921
      Author: gauravj@adobe.com
      Date: 2008-10-28 06:23:00 -0700 (Tue, 28 Oct 2008)
      Log Message:
      Fix for - @inheritDoc tag not working for get/set overrides when you only override the setter of a base class
      QE Notes: Baselines for framework test will need to be updated.
      Doc Notes: None
      Reviewer: Paul
      Bugs: SDK-17304
      tests: checkintests
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17304
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ASDocExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ClassTable.java
