0 Replies Latest reply on Oct 31, 2008 1:06 PM by Chet Haase
    [svn] 3986: Fixed 17833 and 17866.
    Chet Haase Level 3
      Revision: 3986
      Author: chaase@adobe.com
      Date: 2008-10-31 14:06:15 -0700 (Fri, 31 Oct 2008)
      Log Message:
      Fixed 17833 and 17866. Most of these files fix 17833, which enables opt-in behavior of reversing a transition in place, rather than the current snap-to-end behavior, via the new Effect property "autoReverse". Also, FxRotate changes fix 17866, where it was not taking into account any constraints or position set on the object, so that transitions with just an FxRotate would not properly reset any constraints to their from-state values.
      QE Notes:
      Doc Notes: Fixed
      problem in a UIComponent ASDoc comment
      Bugs: sdk-17833, sdk-17866
      Reviewer: Jason
      Tests: checkintests, Mustella (Effects, gumbo/effects, ListDataEffects)
      Ticket Links:
      http://bugs.adobe.com/jira/browse/sdk-17833
      http://bugs.adobe.com/jira/browse/sdk-17866
      Modified Paths:
      flex/sdk/branches/gumbo_alpha/frameworks/projects/flex4/src/mx/effects/Animation.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/flex4/src/mx/effects/FxRotate.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/flex4/src/mx/effects/effectClasses/FxAn imateInstance.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/src/mx/effects/Effect.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/src/mx/effects/EffectInstance .as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/src/mx/effects/IEffect.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/src/mx/effects/IEffectInstanc e.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/src/mx/effects/effectClasses/ CompositeEffectInstance.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/src/mx/effects/effectClasses/ ParallelInstance.as
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/src/mx/effects/effectClasses/ TweenEffectInstance.as
