0 Replies Latest reply on Mar 18, 2008 3:42 PM by (Jono_Spiro)
    [svn] 856: compiler: Removing ArrayUtil. java because it does nothing other than add a level of indirection to the identical API in java .util.Arrays.
    Level 1
      Revision: 856
      Author: jspiro@adobe.com
      Date: 2008-03-18 16:42:55 -0700 (Tue, 18 Mar 2008)
      Log Message:
      compiler: Removing ArrayUtil.java because it does nothing other than add a level of indirection to the identical API in java.util.Arrays.
      Modified Paths:
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/DValue.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/DebugCLI.java
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/FileInfoCache.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/actions/ConstantPool.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/actions/DefineFunction.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/actions/Unknown.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineBinaryData.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineBits.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineBitsJPEG3.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineBitsLossless.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineButton.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineFont.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineFontAlignZones.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineFontInfo.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineSound.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/VideoFrame.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/ZoneRecord.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SwfxParser.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/types/ActionList.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/types/FlashUUID.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/types/Gradient.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/types/MorphFillStyle.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/types/SoundInfo.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/types/TextRecord.java
      Removed Paths:
      flex/sdk/trunk/modules/swfutils/src/java/flash/util/ArrayUtil.java
