0 Replies Latest reply on Nov 4, 2008 8:01 AM by (Jim_Murphy)
    [svn] 4012: Merged trunk revisions 3747,3820,3841,3873,3877,3921,3967-3968, 3993,3995,4000 -> gumbo_alpha
    Level 1
      Revision: 4012
      Author: jimurphy@adobe.com
      Date: 2008-11-04 08:01:18 -0800 (Tue, 04 Nov 2008)
      Log Message:
      Merged trunk revisions 3747,3820,3841,3873,3877,3921,3967-3968,3993,3995,4000 -> gumbo_alpha
      -These all pertain to Asdoc
      Modified Paths:
      flex/sdk/branches/gumbo_alpha/asdoc/build.xml
      flex/sdk/branches/gumbo_alpha/asdoc/projects-asdoc.xml
      flex/sdk/branches/gumbo_alpha/asdoc/templates/ASDoc_Config_Base.xml
      flex/sdk/branches/gumbo_alpha/asdoc/templates/asdoc-util.xslt
      flex/sdk/branches/gumbo_alpha/asdoc/templates/class-files.xslt
      flex/sdk/branches/gumbo_alpha/asdoc/templates/class-parts.xslt
      flex/sdk/branches/gumbo_alpha/asdoc/templates/fieldSummary.xslt
      flex/sdk/branches/gumbo_alpha/asdoc/templates/methodSummary.xslt
      flex/sdk/branches/gumbo_alpha/frameworks/projects/airframework/build.xml
      flex/sdk/branches/gumbo_alpha/frameworks/projects/flash-integration/build.xml
      flex/sdk/branches/gumbo_alpha/frameworks/projects/flex/build.xml
      flex/sdk/branches/gumbo_alpha/frameworks/projects/flex4/build.xml
      flex/sdk/branches/gumbo_alpha/frameworks/projects/framework/build.xml
      flex/sdk/branches/gumbo_alpha/frameworks/projects/haloclassic/build.xml
      flex/sdk/branches/gumbo_alpha/frameworks/projects/rpc/build.xml
      flex/sdk/branches/gumbo_alpha/frameworks/projects/utilities/build.xml
      flex/sdk/branches/gumbo_alpha/frameworks/projects/wireframe/build.xml
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/compiler/asdoc/ASDocExtensi on.java
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.jav a
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/compiler/asdoc/AsDocHelper. java
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/compiler/asdoc/AsDocUtil.ja va
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/compiler/asdoc/ClassTable.j ava
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/compiler/asdoc/DocCommentTa ble.java
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/compiler/asdoc/TopLevelClas sesGenerator.java
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/compiler/mxml/lang/Standard Defs.java
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/configuration_en.properties
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/tools/ASDoc.java
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/tools/ASDocConfiguration.ja va
      flex/sdk/branches/gumbo_alpha/modules/compiler/src/java/flex2/tools/ASDoc_en.properties
      Property Changed:
