Revision: 4016<br />Author: gauravj@adobe.com<br />Date: 2008-11-04 13:23:50 -0800 (Tue, 04 Nov 2008)<br /><br />Log Message:<br />-----------<br />Modify build files to use the <asdoc> task.<br /><br />QE Notes: None<br />Doc Notes: None <br />tests: checkintests<br /><br />Modified Paths:<br />--------------<br /> flex/sdk/trunk/asdoc/build.xml<br /> flex/sdk/trunk/frameworks/projects/airframework/build.xml<br /> flex/sdk/trunk/frameworks/projects/flash-integration/build.xml<br /> flex/sdk/trunk/frameworks/projects/flex/build.xml<br /> flex/sdk/trunk/frameworks/projects/flex4/build.xml<br /> flex/sdk/trunk/frameworks/projects/framework/build.xml<br /> flex/sdk/trunk/frameworks/projects/haloclassic/build.xml<br /> flex/sdk/trunk/frameworks/projects/rpc/build.xml<br /> flex/sdk/trunk/frameworks/projects/utilities/build.xml<br /> flex/sdk/trunk/frameworks/projects/wireframe/build.xml<br /><br />Removed Paths:<br />-------------<br /> flex/sdk/trunk/asdoc/projects-asdoc.xml
