0 Replies Latest reply on Nov 4, 2008 4:43 PM by (Ryan_Frishberg)
    [svn] 4020: When setItemAt() is called on a datagroup's dataProvider, we were removing the old item and adding the new one immediately.
      Revision: 4020
      Author: rfrishbe@adobe.com
      Date: 2008-11-04 16:43:18 -0800 (Tue, 04 Nov 2008)
      Log Message:
      When setItemAt() is called on a datagroup's dataProvider, we were removing the old item and adding the new one immediately. However, when someone tries to do a swap with: getItem1, getItem2, setItemAt(item1, index2), setItemAt(item2, index1), we are temporarily in an inconsistent state. Since this worked in Halo, to get it to work in Gumbo, we just delay any work until commitProperties(). This way, we are in a consistent state. It could be a performance hit, but setItemAt() probably isn't used very often.
      We need to go back and look at setItemAt and see what we should do with these cases where an item appears twice in the list and whether the item is a visual item or just a data item.
      Also, some random ASDoc and other fixes.
      QE Notes: Exclude failing tests. File a bug for these tests.
      Doc Notes: None
      Bugs: SDK-16956, SDK-17909
      Reviewer: Glenn
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16956
      http://bugs.adobe.com/jira/browse/SDK-17909
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/DataGroup.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/GroupBase.as
