0 Replies Latest reply on Nov 5, 2008 11:10 AM by Peter Farland
    [svn] 4023: Interim check-in for FXG as SWF graphics primitives, integrating Kaushal' s prototype of programmatic linkage of TextGraphic instances with the appropriate parent DefineSprite in the SWF display list .
    Peter Farland Level 3
      Revision: 4023
      Author: pfarland@adobe.com
      Date: 2008-11-05 11:10:38 -0800 (Wed, 05 Nov 2008)
      Log Message:
      Interim check-in for FXG as SWF graphics primitives, integrating Kaushal's prototype of programmatic linkage of TextGraphic instances with the appropriate parent DefineSprite in the SWF display list. This change temporarily adds awareness to [Embed] to allow sprites to be constructed from .fxg files.
      QA: No
      Doc: No
      Checkintests: Pass
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Transcoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/dom/AbstractTextNode.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/dom/GraphicContentNode.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/dom/GraphicNode.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/dom/GroupDefinitionNode.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/dom/GroupNode.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/dom/TextGraphicNode.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/dom/text/ParagraphNode.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/dom/text/TextNode.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/sax/FXGSAXScanner.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/TypeHelper.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tags/DefineSprite.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/FXGTranscoder.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/AbstractFXGGraphics.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/SpriteClass.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/TextFXGGraphics.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/TextHelper.java
      Removed Paths:
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/FXGSWFGraphics.java
