0 Replies Latest reply on Nov 6, 2008 3:38 PM by Jason Szeto
    [svn] 4035: RadialGradient and GradientEntry bug fixes
    Jason Szeto Level 3
      Revision: 4035
      Author: jszeto@adobe.com
      Date: 2008-11-06 15:38:55 -0800 (Thu, 06 Nov 2008)
      Log Message:
      SDK-17745 - MXML application with multiple identical gradient fills doesn't render correctly
      RadialGradient now takes into account the x/y position of the graphic element's bounds.
      SDK-17652 - AI import; non-default angle and location of gradients are not retained on import of .ai or .fxg.
      RadialGradient now rotates as expected. Previously, we set rotation using the Matrix.createGradientBox function. But this only rotate the gradients themselves and not the shape of the gradient as defined by scaleX and scaleY. Instead, we need to translate the center of the gradient to 0,0, rotate it, and then translate it back to the original location.
      SDK-17654 - GradientEntry ratio behavior is inconsistent between MXML and ActionScript
      Changed the default value for the ratio parameter in the GradientEntry constructor from -1 to NaN. GradientEntry was probably written before we had support for NaN in the language.
      Added a couple of comments and removed some dead code.
      QE Notes: Please test rotation on RadialGradient and graphic elements with top/left or x/y defined and a RadialGradient fill.
      Doc Notes: Change default value of ratio parameter for GradientEntry constructor.
      Bugs: SDK-17745, SDK-17652, SDK-17654
      Reviewer:
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-17745
      http://bugs.adobe.com/jira/browse/SDK-17652
      http://bugs.adobe.com/jira/browse/SDK-17654
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/FxContainer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/components/baseClasses/GroupBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/mx/graphics/graphicsClasses/GraphicElement.a s
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientEntry.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradient.as
