0 Replies Latest reply on Nov 7, 2008 10:14 AM by Peter Farland
    [svn] 4052: Moving the Flex specific text-capable implementation of AbstractFXGGraphics (i.e.
    Peter Farland Level 3
      Revision: 4052
      Author: pfarland@adobe.com
      Date: 2008-11-07 10:14:55 -0800 (Fri, 07 Nov 2008)
      Log Message:
      Moving the Flex specific text-capable implementation of AbstractFXGGraphics (i.e. TextFXGGraphics) to the compiler module as it is not relevant to swfutils. Adding an implementation of AbstractFXGGraphics as FXGGraphics that simply ignores FXG TextGraphic nodes. To assist switching between these implementations during development, I'm adding a temporary Embed parameter called "ignoreText" that can be set to true or false for .fxg assets.
      QE: No
      Doc: No
      Checkintests: Pass
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/FXGTranscoder.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/SpriteClass.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/TextFXGGraphics.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/TextHelper.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/FXGGraphics.java
      Removed Paths:
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/SpriteClass.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/TextFXGGraphics.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/fxg/swf/TextHelper.java
