0 Replies Latest reply on Mar 19, 2008 8:09 AM by Peter Farland
    [svn] 860: Exposing compiler phase benchmarking to the OEM Compiler API to assist in compiler performance investigation .
    Peter Farland Level 3
      Revision: 860
      Author: pfarland@adobe.com
      Date: 2008-03-19 09:09:30 -0700 (Wed, 19 Mar 2008)
      Log Message:
      Exposing compiler phase benchmarking to the OEM Compiler API to assist in compiler performance investigation. I would have preferred to also refactor the compiler phase benchmarking code into the top level compiler Benchmark system but we need this data exposed right now.
      QA: Yes, it'd be great to capture this info in our performance database. Let's discuss what tests we want to add and how to record the phase information.
      Doc: No
      Checkintests: Pass
      Reviewer: Bruce
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerBenchmarkHelper.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/AbstractCompiler.java
