0 Replies Latest reply on Nov 11, 2008 12:24 PM by Gaurav J
    [svn] 4069: Fix for - an inherited read-write property is reported as write-only if an overriding setter is present and getter is absent .
    Gaurav J Adobe Employee
      Revision: 4069
      Author: gauravj@adobe.com
      Date: 2008-11-11 12:24:53 -0800 (Tue, 11 Nov 2008)
      Log Message:
      Fix for - an inherited read-write property is reported as write-only if an overriding setter is present and getter is absent.
      Constructor for mxml files will now have the default comment "Constructor"
      Also fix for asdoc help details doesn;t show description
      QE Notes: Baselines need to be updated.
      Doc Notes: None
      Bugs: SDK-16091, SDK-17863
      tests: checkintests
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16091
      http://bugs.adobe.com/jira/browse/SDK-17863
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsClass.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/TopLevelClassesGenerator.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
